My project was modified a little, platformio could not be programmed, which showed “ERROR: Failed to prepare for programming.” it could enter the debugging interface, but debugging was abnormal.But I erased the chip, and platformio was programmed and debugged.Before use is normal, but not now, how should I solve this problem excuse me?
undefinedWarning! `env_default` configuration option in section [platformio] is deprecated and will be removed in the next release! Please use `default_envs` instead
Preparing firmware for debugging...
Processing STM32F1 (platform: https://github.com/platformio/platform-ststm32.git; framework: arduino; board: genericSTM32F103RC)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/genericSTM32F103RC.html
PLATFORM: ST STM32 5.7.0 #cad41e7 > STM32F103RC (48k RAM. 256k Flash)
HARDWARE: STM32F103RCT6 72MHz, 48KB RAM, 256KB Flash
DEBUG: Current (jlink) External (blackmagic, jlink, stlink)
PACKAGES: toolchain-gccarmnoneeabi 1.70201.0 (7.2.1), framework-arduinoststm32-maple 1.10000.190819 (1.0.0)
Converting Marlin.ino
Found 37 compatible libraries
|-- <LiquidCrystal> 1.3.4
| |-- <Wire> 1.0
|-- <TMCStepper> 0.4.5
| |-- <SPI> 1.0
|-- <30aa480>
| |-- <Wire> 1.0
|-- <Arduino-L6470> 0.7.0
|-- <SailfishLCD> #e35d62c
|-- <SailfishRGB_LED> #4d0c888
| |-- <Wire> 1.0
|-- <SlowSoftI2CMaster> #3a18be5
|-- <STM32ADC> 1.0
|-- <SPI> 1.0
|-- <EEPROM>
|-- <Wire> 1.0
Building in debug mode
Checking size .pioenvs\STM32F1\firmware.elf
DATA: [==== ] 44.6% (used 21936 bytes from 49152 bytes)
PROGRAM: [======== ] 75.0% (used 196732 bytes from 262144 bytes)
========================= [SUCCESS] Took 14.50 seconds =========================
Environment Status Duration
megaatmega2560 IGNORED
megaatmega1280 IGNORED
at90usb1286_cdc IGNORED
at90usb1286_dfu IGNORED
DUE IGNORED
DUE_USB IGNORED
DUE_debug IGNORED
LPC1768 IGNORED
LPC1769 IGNORED
melzi IGNORED
melzi_optiboot IGNORED
rambo IGNORED
sanguino_atmega644p IGNORED
sanguino_atmega1284p IGNORED
STM32F1 SUCCESS 00:00:14.498
STM32F4 IGNORED
ARMED IGNORED
mks_robin IGNORED
teensy35 IGNORED
malyanm200 IGNORED
esp32 IGNORED
fysetc_f6_13 IGNORED
linux_native IGNORED
========================= 1 succeeded in 00:00:14.498 =========================
SEGGER J-Link GDB Server V6.52 Command Line Version
JLinkARM.dll V6.52 (DLL compiled Sep 27 2019 17:50:11)
Command line: -singlerun -if SWD -select USB -device STM32F103RC -port 2331
-----GDB Server start settings-----
GDBInit file: none
GDB Server Listening port: 2331
SWO raw output listening port: 2332
Terminal I/O port: 2333
Accept remote connection: localhost only
Generate logfile: off
Verify download: off
Init regs on start: off
Silent mode: off
Single run mode: on
Target connection timeout: 0 ms
------J-Link related settings------
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
------Target related settings------
Target device: STM32F103RC
Target interface: SWD
Target interface speed: 4000kHz
Target endian: little
Connecting to J-Link...
Reading symbols from d:\Documents\Desktop\Testmini\Marlin-bugfix-2.0.x\.pioenvs\STM32F1\firmware.elf...
done.
PlatformIO: debug_tool = jlink
J-Link is connected.
Firmware: J-Link V9 compiled Jun 2 2222 22:22:22
Hardware: V9.00
S/N: 30000299
Feature(s): GDB, RDI, FlashBP, FlashDL, JFlash, RDDI
Checking target voltage...
Target voltage: 3.35 V
Listening on TCP/IP port 2331
Connecting to target...
0x0801617a in Temperature::isCoolingHotend (e=0 '\000') at Marlin\src\module/temperature.h:602
602 return temp_hotend[HOTEND_INDEX].target < temp_hotend[HOTEND_INDEX].current;
Connected to target
Waiting for GDB connection...Connected to 127.0.0.1
Reading all registers
Read 2 bytes @ address 0x08019FAC (Data = 0xB508)
Read 2 bytes @ address 0x08022F04 (Data = 0x4770)
Read 4 bytes @ address 0x0801617A (Data = 0xF9FFF003)
Received monitor command: clrbp
Received monitor command: speed auto
Select auto target interface speed (2000 kHz)
Loading section .text, size 0x2b064 lma 0x8000000
Downloading 15952 bytes @ address 0x08000000
Downloading 16160 bytes @ address 0x08003E50
Downloading 16208 bytes @ address 0x08007D70
Downloading 16128 bytes @ address 0x0800BCC0
Downloading 16144 bytes @ address 0x0800FBC0
Downloading 16080 bytes @ address 0x08013AD0
Downloading 16080 bytes @ address 0x080179A0
Downloading 15968 bytes @ address 0x0801B870
Downloading 16016 bytes @ address 0x0801F6D0
Downloading 16064 bytes @ address 0x08023560
Downloading 15428 bytes @ address 0x08027420
Downloading 400 bytes @ address 0x0802B068
Downloading 4160 bytes @ address 0x0802B1F8
Loading section .ARM.exidx, size 0x190 lma 0x802b068
Loading section .data, size 0x1040 lma 0x802b1f8
Downloading 15940 bytes @ address 0x0802C238
Loading section .rodata, size 0x3e44 lma 0x802c238
Start address 0x80003f8, load size 196728
Transfer rate: 5192 KB/sec, 14052 bytes/write.
RAM check failed @ addr 0x20001458.
RAM check failed while testing 0x1060 bytes @ addr 0x2000075C.
Writing register (PC = 0x 80003f8)
Received monitor command: reset
Resetting target
Temporary breakpoint 1 at 0x8003b9e: file C:\users\sengong\.platformio\packages\framework-arduinoststm32-maple\STM32F1\cores\maple\main.cpp, line 38.
Resetting target
Received monitor command: halt
Halting target CPU...
...Target halted (PC = 0x080003F8)
Read 4 bytes @ address 0x080003F8 (Data = 0x468D4901)
Read 2 bytes @ address 0x080003F8 (Data = 0x4901)
Reading 64 bytes @ address 0x08003B80
Read 2 bytes @ address 0x08003B9E (Data = 0xF001)
Reading 64 bytes @ address 0x08014AC0
Read 2 bytes @ address 0x08014ACE (Data = 0x4805)
PlatformIO: Resume the execution to `debug_init_break = tbreak main`
PlatformIO: More configuration options -> http://bit.ly/pio-debug
Setting breakpoint @ address 0x08003B9E, Size = 2, BPHandle = 0x0001
Setting breakpoint @ address 0x08014ACE, Size = 2, BPHandle = 0x0002
Starting target CPU...
...Breakpoint reached @ address 0x08003B9E
Removing breakpoint @ address 0x08003B9E, Size = 2
Removing breakpoint @ address 0x08014ACE, Size = 2
Read 4 bytes @ address 0x08003B9E (Data = 0xFA33F001)
Temporary breakpoint 1, main () at C:\users\sengong\.platformio\packages\framework-arduinoststm32-maple\STM32F1\cores\maple\main.cpp:38
38 setup();
