I am using vs code.
I am using stm32f103 and I am using cubemx platform.
However, the libraries of sensors mostly use the arduino platform.
I am trying to port because I want to use such a library.
The problem is that the path of header files cannot be found as the first gateway.
So I want to add the path where the libraries in other paths are.
please tell me how to do it
For reference, the terminal log is as follows:
Processing genericSTM32F103VE (platform: ststm32; board: genericSTM32F103VE; framework: stm32cube)
-------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/genericSTM32F103VE.html
PLATFORM: ST STM32 (14.0.0) > STM32F103VE (64k RAM. 512k Flash)
HARDWARE: STM32F103VET6 72MHz, 64KB RAM, 512KB Flash
DEBUG: Current (jlink) External (blackmagic, cmsis-dap, jlink, stlink)
- framework-stm32cubef1 1.8.3
- tool-ldscripts-ststm32 0.1.0
Found 28 compatible libraries
Building in debug mode
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_adc.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_adc_ex.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_can.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_cec.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_cortex.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_crc.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_dac.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_dac_ex.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_dma.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_eth.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_exti.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_flash.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_flash_ex.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_gpio.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_gpio_ex.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_hcd.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_i2c.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_i2s.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_irda.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_iwdg.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_mmc.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_nand.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_nor.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_pccard.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_pcd.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_pcd_ex.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_pwr.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_rcc.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_rcc_ex.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_rtc.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_rtc_ex.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_sd.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_smartcard.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_spi.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_sram.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_tim.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_tim_ex.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_uart.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_usart.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_hal_wwdg.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_adc.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_crc.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_dac.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_dma.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_exti.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_fsmc.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_gpio.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_i2c.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_pwr.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_rcc.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_rtc.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_sdmmc.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_spi.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_tim.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_usart.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_usb.o
Compiling .pio\build\genericSTM32F103VE\FrameworkHALDriver\Src\stm32f1xx_ll_utils.o
Compiling .pio\build\genericSTM32F103VE\src\main.o
Compiling .pio\build\genericSTM32F103VE\src\stm32f1xx_hal_msp.o
Compiling .pio\build\genericSTM32F103VE\src\stm32f1xx_it.o
Compiling .pio\build\genericSTM32F103VE\src\system_stm32f1xx.o
Compiling .pio\build\genericSTM32F103VE\FrameworkCMSISDevice\gcc\startup_stm32f103xe.o
Compiling .pio\build\genericSTM32F103VE\FrameworkCMSISDevice\system_stm32f1xx.o
src\main.c:22:10: fatal error: main.h: No such file or directory
* Looking for main.h dependency? Check our library registry!
* CLI > platformio lib search "header:main.h"
* Web > https://platformio.org/lib/search?query=header:main.h
#include "main.h"
compilation terminated.
src\stm32f1xx_hal_msp.c:23:10: fatal error: main.h: No such file or directory
#include "main.h"
*** [.pio\build\genericSTM32F103VE\src\main.o] Error 1
src\stm32f1xx_it.c:22:10: fatal error: main.h: No such file or directory
#include "main.h"
*** [.pio\build\genericSTM32F103VE\src\stm32f1xx_hal_msp.o] Error 1
*** [.pio\build\genericSTM32F103VE\src\stm32f1xx_it.o] Error 1
============================================== [FAILED] Took 4.83 seconds ==============================================
The terminal process "C:\Users\ilk48\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
This is the content of the platformio.ini I tried.
[evn]
lib_dir =
-I Middlewares/ST
-I D:/00_Schaffengott/107_FireStation/02_Firmware/STM32F103_JTAG_TEST/Inc
-I D:/00_Schaffengott/107_FireStation/02_Firmware/STM32F103_JTAG_TEST/.pio/libdeps/genericSTM32F103VE/Adafruit HTU21DF Library
src_dir = D:/00_Schaffengott/107_FireStation/02_Firmware/STM32F103_JTAG_TEST/src
[env:genericSTM32F103VE]
platform = ststm32
board = genericSTM32F103VE
framework = stm32cube
build_type = debug
debug_tool = jlink
board_debug.jlink_device = STM32F103VE
upload_protocol = jlink
lib_deps = adafruit/Adafruit HTU21DF Library@^1.0.5
Thank you for your help.
