this error message pops up during VS code PIO startup{
“resource”: “/c:/Users/Carl/Documents/PlatformIO/Projects/Teensy_sequencer_V2/.vscode/c_cpp_properties.json”,
“owner”: “c:\Users\Carl\Documents\PlatformIO\Projects\Teensy_sequencer_V2”,
“severity”: 4,
“message”: “Cannot find “C:\Users\Carl\.platformio\packages\toolchain-gccarmnoneeabi@1.50401.190816\bin\arm-none-eabi-gcc.exe”.”,
“startLineNumber”: 255,
“startColumn”: 29,
“endLineNumber”: 255,
“endColumn”: 131
when I try to compile i get ModuleNotFoundError ‘elftools’ :
Can you post the full error log that appears when you do the “Build” task?
here is the terminal window response.
ModuleNotFoundError: No module named 'elftools':
File "C:\Users\Carl\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 91:
env = DefaultEnvironment(**DEFAULT_ENV_OPTIONS)
File "C:\Users\Carl\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Defaults.py", line 86:
_default_env = SCons.Environment.Environment(*args, **kw)
File "C:\Users\Carl\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Environment.py", line 999:
apply_tools(self, tools, toolpath)
File "C:\Users\Carl\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Environment.py", line 102:
env.Tool(tool)
File "C:\Users\Carl\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Environment.py", line 1843:
tool = SCons.Tool.Tool(tool, toolpath, **kw)
File "C:\Users\Carl\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Tool\__init__.py", line 119:
module = self._tool_module()
File "C:\Users\Carl\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Tool\__init__.py", line 205:
module = spec.loader.load_module(spec.name)
File "<frozen importlib._bootstrap_external>", line 407:
File "<frozen importlib._bootstrap_external>", line 907:
File "<frozen importlib._bootstrap_external>", line 732:
File "<frozen importlib._bootstrap>", line 265:
File "<frozen importlib._bootstrap>", line 696:
File "<frozen importlib._bootstrap>", line 677:
File "<frozen importlib._bootstrap_external>", line 728:
File "<frozen importlib._bootstrap>", line 219:
File "C:\Users\Carl\.platformio\penv\lib\site-packages\platformio\builder\tools\piosize.py", line 23:
from elftools.elf.descriptions import describe_sh_flags
Can you please first remove all folders C:\Users\Carl\.platformio\packages\toolchain-gccarmnoneeabi*
completely and press “Build” again?
Otherwise your PlatformIO installation looks broken and I’ll post a link to a reinstallation guide if that does not help.
Thanks Maxgerhardt, I will try and let you know shortly
looks like similar issue
Tool Manager: Installing platformio/toolchain-gccarmnoneeabi @ ~1.50401.0
Tool Manager: toolchain-gccarmnoneeabi @ 1.50401.190816 has been installed!
env.Tool(tool)
================================================================== [FAILED] Took 61.60 seconds ==================================================================
The terminal process "C:\Users\Carl\.platformio\penv\Scripts\pio.exe 'run', '--environment', 'teensy41'" terminated with exit code: 1.
Please do the following:
- Open a PlatformIO CLI
- Execute
pio upgrade --dev
- Execute
pio platform update
- Restart VSCode
- Rebuild the project.
If that does not work, it’s re-install time.
ok thanks, I’ll need to figure out how to do the Command line stuff as the cli is not an option under Miscellaneous on my installation
I just use the terminal correct?
If that’s the case then your PlatformIO installation seems heavily outdated.
- In VSCode, remove the PlatformIO extension
- Remove the folder
completely - Reinstall the PlatformIO VSCode extension from the marketplace, wait for installation, then restart VSCode
- Rebuild project
OK Max, Thanks will do
Max,reload and rebuild worked Thankyou !!
