Hi. I’ve been using Plataform.io for a few days. Today I had to reinstall the software for a crash with the terminal part. After that I cant upload SPIFFS. It says “file too big”
I have another PC and works ok. The only thing i noticed is a difference in this line…
Are exactly the same because 0x300000 = 3145728. What’s the size of the SPIFFs binary you’re trying to upload (i.e. file size of .pioenvs\nodemcuv2\spiffs.bin)?
I’ve tried 3m and 1m using env flags and no one works. The same project uploads corectly online the other pc… If I can connect to mybwork PC I Will upload the log. Thx
data folder is empty and the bin size is 1028096 bytes
22/06/2018 14:30 259.696 firmware.bin
the output of the upload log
Processing nodemcuv2 (platform: espressif8266; board: nodemcuv2; framework: arduino)
PLATFORM: Espressif 8266 > NodeMCU 1.0 (ESP-12E Module)
SYSTEM: ESP8266 80MHz 80KB RAM (4MB Flash)
Collected 26 compatible libraries
"mkspiffs" -c data -p 256 -b 8192 -s 1028096 .pioenvs\nodemcuv2\spiffs.bin
MethodWrapper(["uploadfs"], [".pioenvs\nodemcuv2\spiffs.bin"])
Auto-detected: COM4
esptool -vv -cd nodemcu -cb 115200 -cp "COM4" -ca 3145728 -cf .pioenvs\nodemcuv2\spiffs.bin
esptool v0.4.13 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to nodemcu
setting baudrate from 115200 to 115200
setting port from COM1 to COM4
setting address from 0x00000000 to 0x03145728
espcomm_upload_file
espcomm_upload_mem
setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
flush start*** [uploadfs] Error 2
setting serial port timeouts to 1 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
read 0, requested 1
trying to connect
flush start
flush complete
espcomm_send_command: receiving 2 bytes of data
Uploading 1028096 bytes from .pioenvs\nodemcuv2\spiffs.bin to flash at 0x03145728
erasing flash
size: 0fb000 address: 3145728
warning: Invalid size/address, too large: fb000 3145728
warning: espcomm_send_command(FLASH_DOWNLOAD_BEGIN) failed
closing bootloader
flush start
flush complete
error: espcomm_upload_mem failed
================================================== [ERROR] Took 2.01 seconds
I don’t know what to do. The same project upload ok on the same chip at another PC
Oh I know what could be the error. I said in the first post. PIO now gives the flash address in decimal instead of hexadecimal, somehow the tool doesn’t like it. @ivankravets?
Yesterday i had to reinstall coz the terminal broke for no reasons. When I did that the espressif8266 sdk had to be updated. The terminal begin to work but the upload starts to fail
