I broke something in Arduino Uno after flashings it with USBasp
I flushed Arduino Uno via USBASP programmer, because I needed to be sure that the programmer is working.
I used this config for platfromio (c) source:
[env:program_via_USBasp]
board = uno
build_flags = -I include ; This is required for my file organization.
upload_protocol = custom
upload_port = usb
upload_flags =
    -C
    ; use "tool-avrdude-megaavr" for the atmelmegaavr platform
    ${platformio.packages_dir}/tool-avrdude/avrdude.conf
    -p
    $BOARD_MCU
    -P
    $UPLOAD_PORT
    -c
    usbasp
	sui77/rc-switch@^2.6.4
It works fine. But no I can’t flush that controller via USB port:
Uploading .pio/build/uno/firmware.hex
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x6b
Configuration:
[env:uno]
board = uno
upload_port = /dev/ttyUSB*
upload_speed = 115200
monitor_port = /dev/ttyUSB*
It is worked before using USBASP programmer. And controller still supports a serial monitor, there is no problems.
I suppose, I broke a bootloader. But how I made it and what I should do now - I don’t know. Any suggestions?
I tried to repair bootloader:
pio run --target bootloader
Another problem:
avrdude: ser_open(): can’t open device “unknown”: No such file or directory
Same with both connections: USB port on plate and via programmer on ICSP pins.
Greate! I repaired the bootloader (I chose the wrong configuration before). But I still don’t know, how I broke it.
I’m not sure, but you could possibly have overwritten bootloader with your custom firmware. The bootloader and firmware are flashed to the same memory region, only memory addresses are different. Usually PlatformIO handles that for you, but I see you supplied a custom upload_command – please check which address does it flash the firmware to.
I think you’re close to the truth. I did not find any ways to specify memory addresses for writing firmware, but I found something in the official documentation. This command:
upload_command = ... -U flash:w:$SOURCE:i
And documetation explanation:
-U memtype:op:filename[:format]
memtype
flash
The flash ROM of the device.
I suppose, it is starting to write from the first address in flash. But there was bootloader.
There are other options for memtype:
application
The application flash area of ATxmega devices.
apptable
The application table flash area of ATxmega devices.
I don’t know what this means in the context of avrdude.
When you use an ICSP device like your USBasp or my USBtiny, to upload a sketch, you overwrite the Uno bootloader.
In order to get the bootloader back, you have to rewrite it using the ICSP device. After that operation, you can then upload over USB without using the ICSP device, if you wish.
HTH
Cheers,
Norm.
Yes, I understood. But it looks like shooting in the leg from the official documentation. There are no warnings or so. Just “take this config and be happy”. Even it is highly recommended to use the upload_command option to avoid damaging the controller. It’s pitty.
Anyway, this case can be closed. Thanks for replies.
These seem to reference ATxmega devices, which is a different chip family, not the one Arduino Uno is built on. Maybe they have different flash memory regions.
