I am able to build and upload programs successfully, but no output on my UNO when I use Platform.io
Hello all, I am trying to test out a new arduino Uno I bought. When I run programs via the Arduino IDE it builds/uploads successfully and it functions correctly. When I use VSC PIO though, it builds/uploads successfully, I get indicator lights on the board showing the upload, but it doesn’t actually do anything. I’ve so far only tried it with the blinking example code.
To reiterate, Both IDE’s build and upload successfully. PIO however does not actually blink the LED after the upload. No visible errors in terminal, and code is exact same.
PIO Terminal:
 *  Executing task in folder Arduino Test: C:\Users\Work\.platformio\penv\Scripts\platformio.exe run --target upload
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION:
PLATFORM: Atmel AVR (5.1.0) > Arduino Uno
DEBUG: Current (avr-stub) External (avr-stub, simavr)
 - framework-arduino-avr @ 5.2.0
 - tool-avrdude @ 1.60300.200527 (6.3.0)
LDF: Library Dependency Finder ->
Found 5 compatible libraries
Checking size .pio\build\uno\firmware.elf
RAM:   [          ]   0.4% (used 9 bytes from 2048 bytes)
Flash: [          ]   1.4% (used 444 bytes from 32256 bytes)
AVAILABLE: arduino
Looking for upload port...
Auto-detected: COM6
Uploading .pio\build\uno\firmware.hex
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file ".pio\build\uno\firmware.hex"
avrdude: writing flash (444 bytes):
Writing | ################################################## | 100% 0.09s
avrdude: 444 bytes of flash written
avrdude: verifying flash memory against .pio\build\uno\firmware.hex:
avrdude: load data flash data from input file .pio\build\uno\firmware.hex:
avrdude: input file .pio\build\uno\firmware.hex contains 444 bytes
Reading | ################################################## | 100% 0.06s
avrdude: verifying ...
avrdude: 444 bytes of flash verified
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
avrdude done.  Thank you.
======================== [SUCCESS] Took 2.55 seconds ========================
Arduino IDE:
avrdude: Version 6.3-20190619
         System wide configuration file is "C:\Users\Work\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: reading input file "C:\Users\Work\AppData\Local\Temp\arduino\sketches\A982F225FB44C2EEDD0C43D007224FCB/Blink.ino.hex"
avrdude: writing flash (924 bytes):
Writing | ################################################## | 100% 0.17s
avrdude: 924 bytes of flash written
Code:
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(13, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(13, HIGH);  // turn the LED on (HIGH is the voltage level)
  delay(1000);                      // wait for a second
  digitalWrite(13, LOW);   // turn the LED off by making the voltage LOW
Can you show a screenshot of VSCode with your main code file open?
Mhm okay, then it’s something different than I thought. (If you were to use src/main.c instead of src/main.cpp, I would expect this behavior).
The main suspicious thing is the difference in generated firmware sizes. Under PIO
Under the Arduino IDE 2.0:
And the bigger image is the working one. Let me see what firmware size you should expect…
I noticed that but didnt know what to think
Ok so something changed, I ran the exact same program in vsc. All of a sudden it works now. No restart, nothing. Just works. But, it did go back to 924 instead of 444 bytes. Not sure why
Is the “Documents” folder, under which this project is created, in One Drive? Because that can cause major issues.
No but it is in Google drive, im assuming cloud based storage causes the same issues with it? updating the file doesnt work too well?
I think if there are some syncing issues or time races, when it goes to build the firmware.elf, and gets some older version of some object files or empty content back, then the firmware.elf won’t be build correctly.
Try recreating the project on your regular harddrive and see if this issues occurs, ever?
