Howto select STM32C011 MCU?
As of PlatformIO Registry STM32C011 support is listed.
But whatever I try, I’m to untalented to get support for it.
Whatever I do, I always get “UnknownBoard” error.
Also pio pkg exec --package "platformio/framework-arduinoststm32" -- pio boards doesn’t list any STM32C011 MCU :frowning:
Any suggestions?
There is indeed no board definition for it and the only issue about it was closed prematurely (https://github.com/search?q=repo%3Aplatformio%2Fplatform-ststm32+stm32c0+&type=issues).
Which C011 chip or board are we talking about exactly?
Quite thanks for replying!
Good to know that I didn’t missed to read some docs :wink:
It’s a custom designed board with STM32C011F6P6 without external xtal/osc.
Assuming you’re running Windows, can I ask you to test this project?
It compiles for a generic STM32C011F6P6 with no clock requirements. I had to add an updated version of OpenOCD into it because PlatformIO’s 1 year old version did not have STM32C0x support. Albeit C++ (register) warnings from the STM32HAL, it compiles fine.
Hurray, quick as always!! :wink: Thanks a lot!!
Unfortunately I dropped Windows approx. 15 years ago :innocent:.
However, it also compiles well on my Linux (debian 12.x) machine (with a lot warnings related to clock, HAL, …).
Unfortunately the board just get produced and I expect to receive it earliest next week. So I can’t test right now :frowning:
BUT: Many thanks for your quick support!! I can go on now with development.
The warning about the clock were actually fixed some time ago https://github.com/stm32duino/Arduino_Core_STM32/commit/75bda51e7c6d79415326ac43a199ee36200d93a1, I tracked that down. But there hasn’t been a new stable release since then by STM32Duino.
This seems important, so I did just include the current git commit version manually and added a surpression for -Wregister warnings to not spam the output. Now it builds cleanly. (Git project updated)
The issues about -Wregister warnings were raised in
Thank you very much!! :heart_eyes:
In between I received my custom boards with the STM32C011F6 and can confirm that it’s working well! :+1:
However, I’ve a problem remapping PA9/PA11 and PA10/PA12 to get USART1 on pin 16 (TX) and 17 (RX). Already tried some stuff but need to confess that I miss some generic understanding.
What I tried/understood in general is, that I need to remap those pins, which I tried via:
SYSCFG->CFGR1 |= 0b11000; // Remap PA12 to PA10 and PA11 to PA9
and than expected to get usart1 i.e. via:
HardwareSerial hostSerial(PA10, PA9);
or
HardwareSerial hostSerial(PA12, PA11); ?!?
But my code always freeze at the moment where the handler get attached (but work flawless when using i.e. USART2).
Unfortunately I didn’t found any useful docs how the remapping is handled in stm32duino :grimacing:. Yes I know “code is doc” :innocent:, but that’s the part where I need to admit my personal limits :innocent:
Close! It should be
HardwareSerial hostSerial(PA10_R, PA9_R);
for the alternative (remapped) pins. That uses the int, int constructor. But you can also use the constructor with the PinName, PinName types, that would be
HardwareSerial hostSerial(PA_10_R,  PA_9_R);
You can see that in list of available int type pins
that get remapped to PinName type pins by using them as index in this array
And then the peripheral info is retrieved by searching these arrays for an entry that has the matching PinName type pin
The pin_function specifically then detects that | PREMAP macro for specific pins and calls
Also, if the hostSerial is supposed to be the main Serial object, you can take advantage of the overridable macros that select the instance and pins for that because
So you can have
  -DSERIAL_UART_INSTANCE=1
  -DPIN_SERIAL_RX=PA10_R
  -DPIN_SERIAL_TX=PA9_R
in the platformio.ini so it’ll just overwrite the defaults.
Close :joy: … is also off-target :see_no_evil:
Quite cool!! That compiles and doesn’t freeze anymore. Need to get another USB/UART from downstairs to validate, but I’m pretty sure it will :+1:
Also quite thanks for your detailed description :pray:. Will try to understand and decide which solution is preferable for me.
Took some time to get downstairs :see_no_evil:. Checked remapped UART which work flawless!
Also checked your code explanations. Interesting :face_with_peeking_eye: and I can follow somehow… also might find another remap stuff which I probably need later :+1:
But I’m pretty sure, without your solution and your pointing finger, it has taken hours for me to find that by myself :innocent:
So: Quite thanks one more for your quick support and detailed explanation!
Hi @maxgerhardt, I was able to use your (https://github.com/STMicroelectronics/STM32CubeC0) repository to build for the STM32C0, but I would like to use the stm32cube framework, io. arduino.
So I simply modified the platformio.ini file to framework = stm32cube but this yields following problems…
Processing genericSTM32C011F6 (platform: ststm32@17.4.0; board: genericSTM32C011F6; framework: stm32cube)
KeyError: Traceback (most recent call last):
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\platformio\__main__.py", line 103, in main
    cli()  # pylint: disable=no-value-for-parameter
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\click\core.py", line 1157, in __call__
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\click\core.py", line 1078, in main
    rv = self.invoke(ctx)
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\platformio\cli.py", line 85, in invoke
    return super().invoke(ctx)
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\click\core.py", line 1688, in invoke
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\click\core.py", line 1434, in invoke
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\click\core.py", line 783, in invoke
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\click\decorators.py", line 33, in new_func
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\platformio\run\cli.py", line 147, in cli
    process_env(
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\platformio\run\cli.py", line 210, in process_env
    ).process()
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\platformio\run\processor.py", line 81, in process
    install_project_env_dependencies(
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\platformio\package\commands\install.py", line 132, in install_project_env_dependencies
    _install_project_env_platform(project_env, options),
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\platformio\package\commands\install.py", line 149, in _install_project_env_platform
    PlatformPackageManager().install(
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\platformio\package\manager\platform.py", line 60, in install
    p.configure_project_packages(project_env, project_targets)
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\platformio\platform\base.py", line 185, in configure_project_packages
    self.configure_default_packages(options, targets or [])
  File "C:\Users\pasca\.platformio\platforms\ststm32\platform.py", line 111, in configure_default_packages
    return PlatformBase.configure_default_packages(self, variables,
  File "C:\Users\pasca\.platformio\penv\Lib\site-packages\platformio\platform\base.py", line 197, in configure_default_packages
    self.packages[_pkg_name]["optional"] = False
KeyError: 'framework-stm32cubec0'
I think framework-stm32cubec0 needs to be added to packages.json, but I don’t know how… Could you please advise ?
I added
framework-stm32cubec0@https://github.com/STMicroelectronics/STM32CubeC0
to platformio.ini, and this is certainly a step forward, but the I get a new error
MissingPackageManifestError: Could not find one of 'package.json' manifest files in the package
You need to fork that https://github.com/STMicroelectronics/STM32CubeC0 repo and put a package.json in it, like
  "name": "framework-stm32cubec0",
  "title": "STM32Cube",
  "description": "STM32Cube is a set of tools and embedded software bricks available free of charge to enable fast and easy development on the STM32 platform (STM32CubeC0 MCU Firmware Package)",
  "keywords": [
    "framework",
    "hal",
    "stm32c0",
    "stm32",
    "st"
  "version": "1.4.0",
  "homepage": "https://www.st.com/en/embedded-software/stm32cubec0.html",
  "repository": {
    "type": "git",
    "url": "https://github.com/STMicroelectronics/STM32CubeC0"
then point to that forked repo in your platform_packages.
The original issue that should be pushed is
Platform forks and point wise fixes make no sense in the global context.
Ok, some progress, but still a problem :
The system cannot find the path specified: 'C:\\Users\\pasca\\.platformio\\packages\\tool-ldscripts-ststm32\\stm32c0':
If I checked the folder for tool-ldscripts-ststm32 and there is indeed no subfolder for the C0 family… Reinstalling the tool also did not solve it.
any hints ?
I think you just have to create the folder
C:\Users\pasca\.platformio\packages\tool-ldscripts-ststm32\stm32c0
the builder script wants this folder to exist.
It looks for for a <MCU name>_DEFAULT.ld or <MCU name>_FLASH.ld script inside there, but if it’s not there, it will just use a generic template to generate the linker script. This should work.
If creating it locally works, you can equally create a forked repo for the tool-ldscripts-ststm32 package and link it in platform_packages.
Thank you @maxgerhardt that worked.
I could get the correct STM32C011F6UX_FLASH.ld file from STM32CubeIDE and copied it to that folder.
I still needed to upgrade GCC because the .ld file contained READ_ONLY sections. I found some other thread from you explaining how to solve that.
Build is now successful. Still some linker warnings. I will look into those with a fresh mind tomorrow.
Thanks @maxgerhardt for the info/help. I tried the PlatformIO instance that you shared, and it worked perfectly out of the box.
Only issue is that the Arduino framework ends up consuming basically half of the FLASH just to blink the LEDs and say “hello world.” By the time I’d ported my application code to the project, I was at 91% FLASH utilization–which isn’t going to work, especially if utilizing the “EEPROM” functionality!
Switching to the “stm32cube” framework to get rid of all of the clutter obviously needed a bit of work. However, when checking forks of the https://github.com/STMicroelectronics/STM32CubeC0 repository, I found that someone had made the necessary fixes to not one but both repositories for compilation with “stm32cube”.
Yesterday, too :wink:
The following “platformio.ini” compiles an empty “main.c” without any warnings/errors or issues. A check of the output binary appears to show the vector table where it should be.
[env]
platform = ststm32@19.4.0
extra_scripts = surpress_register_warnings.py
; PlatformIO's OpenOCD package is too outdated to support STM32C0x series
; Downloaded Windows version from https://github.com/xpack-dev-tools/openocd-xpack/releases
; Put package.json inside it, and reference it
platform_packages =
   tool-openocd@symlink://packages/xpack-openocd-0.12.0-3-win32-x64
   tool-ldscripts-ststm32@https://github.com/zuyih/tool-ldscripts-ststm32
   framework-stm32cubec0@https://github.com/zuyih/STM32CubeC0
[env:genericSTM32C011F6]
board = genericSTM32C011F6
[env:genericSTM32C011J6]
board = genericSTM32C011J6
Oh, and only 0.8% FLASH utilization.
Enjoy!
