OK, reference to this article https://community.platformio.org/t/how-to-change-the-ram-size-in-platform/12554
I have got it how to set the build flags to instead of the build_opt.h file,
but there’s some error occurs like the example, if the code without “=”, it will be compiled failed.
How shoud I change the code to aovid this?
official build_opt.h wiki
I have no problems compiling a project with platformio.ini
[env:nucleo_l476rg]
platform = ststm32
board = nucleo_l476rg
-DENABLE_HWSERIAL3
-DPIN_SERIAL3_RX=PB11
-DPIN_SERIAL3_TX=PB10
main.cpp
Serial3.begin(115200);
Serial3.println("Hello world");
delay(1000);
$ pio run
Processing nucleo_l476rg (platform: ststm32; board: nucleo_l476rg; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/nucleo_l476rg.html
PLATFORM: ST STM32 6.1.0 > ST Nucleo L476RG
HARDWARE: STM32L476RGT6 80MHz, 128KB RAM, 1MB Flash
DEBUG: Current (stlink) On-board (stlink) External (blackmagic, jlink)
- framework-arduinoststm32 4.10800.200207 (1.8.0)
- toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
Found 11 compatible libraries
Compiling .pio/build/nucleo_l476rg/src/main.cpp.o
Linking .pio/build/nucleo_l476rg/firmware.elf
Checking size .pio/build/nucleo_l476rg/firmware.elf
Building .pio/build/nucleo_l476rg/firmware.bin
RAM: [ ] 0.9% (used 1116 bytes from 131072 bytes)
Flash: [ ] 1.1% (used 11872 bytes from 1048576 bytes)
============== [SUCCESS] Took 3.34 seconds =====================
Make sure to separate build flags by newline.
Oh, you haven’t put a space before the newline-separated options. Yes that’s must, you must follow the format given in the docs.
