How to use Serial Monitor?
Hello, I have a question regarding the serial monitor.
I have previously been able to get the serial monitor to display a simple “Hello world” text, however, I am no currently getting this in the serial monitor and it is not displaying the output of “hello world”
Executing task in folder Test Project: C:\Users\n\.platformio\penv\Scripts\platformio.exe device monitor
--- Terminal on COM9 | 115200 8-N-1
--- Available filters and text transformations: colorize, debug, default, direct, esp32_exception_decoder, hexlify, log2file, nocontrol, printable, send_on_enter, time
--- More details at https://bit.ly/pio-monitor-filters
--- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H
How do I use PIO’s serial monitor?
As an update, it seems to work fine with my uno, however it’s not working with my ESP32S3.
The code that I am using for both is:
  Serial.begin(9600);
  Serial.println("Hello World!");
Adding to platformio.ini monitor_speed = 9600
monitor_rts = 0
monitor_dtr = 0
also does not work, also have tried changing baud rate from 9600 to 115200.
Seems like it’s a board issue/board firmware issue not serial monitor
