Hi
Finally while working on Industrial automation project I am able to check the sensor reading while interfacing with pycom sipy using 4 Channel current loop receiver but I want to run pycom sipy device under AES mode and I don’t know how to use it .
So I need some guidance in using the AES mode
Is there any option to do modification in coding interface while using the AES mode or not ?
Your advices would be very helpful to me…
Is your code successfully running ??
If you want to run it on AES mode you should check out the documentation of AES mode of Pycom
Hope this will help you
