I’m having a similar issue and I’m not sure how to implement this into a custom python test in the test_custom_runner.py file.
When I go to include a library that I haven’t installed I get an error like this:
UserSideException: Could not find custom test runner by this path -> .../test/embedded/test_custom_runner.py
But when I prefix my python code with this
# ---------------------- PIO SCRIPTING ----------------------
# https://docs.platformio.org/en/stable/scripting/examples/extra_python_packages.html
# Do not format the PIO scripting code. It must be before python imports
# noqa: off
Import("env") # type: ignore
# List installed packages
env.Execute("$PYTHONEXE -m pip list") # type: ignore
# Install custom packages from the PyPi registry
env.Execute("$PYTHONEXE -m pip install pkg1 pkg2") # type: ignore
# Install missed package
try:
from saleae import automation
except ImportError:
env.Execute("$PYTHONEXE -m pip install saleae") # type: ignore
# noqa: on
from platformio.public import TestCase, TestCaseSource, TestStatus, UnityTestRunner
import os
import os.path
from datetime import datetime
# Code here
I get this error
Verbosity level can be increased via `-v, -vv, or -vvv` option
Collected 2 tests
NameError: Traceback (most recent call last):
File "/Users/freddy/.platformio/penv/lib/python3.11/site-packages/platformio/__main__.py", line 103, in main
File "/Users/freddy/.platformio/penv/lib/python3.11/site-packages/click/core.py", line 1157, in __call__
File "/Users/freddy/.platformio/penv/lib/python3.11/site-packages/click/core.py", line 1078, in main
rv = self.invoke(ctx)
File "/Users/freddy/.platformio/penv/lib/python3.11/site-packages/platformio/cli.py", line 85, in invoke
return super().invoke(ctx)
File "/Users/freddy/.platformio/penv/lib/python3.11/site-packages/click/core.py", line 1688, in invoke
File "/Users/freddy/.platformio/penv/lib/python3.11/site-packages/click/core.py", line 1434, in invoke
File "/Users/freddy/.platformio/penv/lib/python3.11/site-packages/click/core.py", line 783, in invoke
File "/Users/freddy/.platformio/penv/lib/python3.11/site-packages/click/decorators.py", line 33, in new_func
File "/Users/freddy/.platformio/penv/lib/python3.11/site-packages/platformio/test/cli.py", line 137, in cli
runner = TestRunnerFactory.new(
File "/Users/freddy/.platformio/penv/lib/python3.11/site-packages/platformio/test/runners/factory.py", line 58, in new
mod = load_python_module(module_name, custom_runner_path)
File "/Users/freddy/.platformio/penv/lib/python3.11/site-packages/platformio/compat.py", line 99, in load_python_module
spec.loader.exec_module(module)
File "<frozen importlib._bootstrap_external>", line 940, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/Users/freddy/Library/Mobile Documents/com~apple~CloudDocs/Code/Arduino/ArduinoUnitPIO/test/embedded/test_custom_runner.py", line 5, in <module>
NameError: name 'Import' is not defined
`python -m pip install -U platformio` command
How do I interface with the virtual environment in this scenario?
