Hi! I’m using Arduino as a component of IDF with platformIO in vscode.
I want to use the latest from both worlds.
Is this possible somehow?
Thank you very much!
My PIO ini file:
[platformio]
build_cache_dir = ./cache
[env:esp-wrover-kit]
check_skip_packages = yes
board = esp-wrover-kit
framework = arduino, espidf
upload_protocol = espota
upload_port = 192.168.10.107
upload_speed = 921600
monitor_filters = colorize, esp32_exception_decoder
board_upload.flash_size = 16MB
board_build.flash_mode = qio
board_build.partitions = ./Partitions/hshPartition_APP_3MB.csv
board_build.f_flash = 80000000L
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
-mfix-esp32-psram-cache-strategy=memw
-DCONFIG_SPIRAM_USE_MALLOC=1
-DCONFIG_MBEDTLS_DYNAMIC_BUFFER=1
-DCONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST=1
-DCONFIG_SPIRAM_CACHE_WORKAROUND=1
-DCORE_DEBUG_LEVEL=0
-std=gnu++17
build_unflags =
-std=gnu++11
