what is wrong here?
Resolving esp32s3_120_16_8-qio_opi dependencies...
Already up-to-date.
Updating metadata for the vscode IDE...
UserSideException: Processing esp32s3_120_16_8-qio_opi (board: esp32s3_120_16_8-qio_opi; platform: https://github.com/pioarduino/platform-espressif32/archive/refs/tags/53.03.13.zip; framework: arduino, espidf)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32s3_120_16_8-qio_opi.html
PLATFORM: Espressif 32 (53.3.13) > ESP32-S3 16MB QIO, 8MB OPI PSRAM
HARDWARE: ESP32S3 240MHz, 320KB RAM, 16MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 @ 3.1.3
- framework-arduinoespressif32-libs @ 5.3.0+sha.489d7a2b3a
- framework-espidf @ 3.50302.0 (5.3.2)
- tool-cmake @ 3.30.2
- tool-esptoolpy @ 4.8.6
- tool-mklittlefs @ 3.2.0
- tool-ninja @ 1.9.0
- tool-riscv32-esp-elf-gdb @ 14.2.0+20240403
- tool-xtensa-esp-elf-gdb @ 14.2.0+20240403
- toolchain-esp32ulp @ 1.23800.240113 (2.38.0)
- toolchain-riscv32-esp @ 13.2.0+20240530
- toolchain-xtensa-esp-elf @ 13.2.0+20240530
Warning! Arduino framework as an ESP-IDF component doesn't handle the `variant` field! The default `esp32` variant will be used.
-- git rev-parse returned 'fatal: not a git repository (or any of the parent directories): .git'
-- Could not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32s3
Processing 11 dependencies:
[1/11] chmorgan/esp-libhelix-mp3 (1.0.3)
[2/11] espressif/cbor (0.6.0~1)
[3/11] espressif/esp-dsp (1.4.12)
[4/11] espressif/esp-sr (1.9.5)
[5/11] espressif/esp-zboss-lib (1.6.0)
[6/11] espressif/esp-zigbee-lib (1.6.0)
[7/11] espressif/esp_modem (1.3.0)
[8/11] espressif/mdns (1.7.0)
[9/11] espressif/network_provisioning (1.0.2)
[10/11] joltwallet/littlefs (1.17.0)
[11/11] idf (5.3.2)
-- Project sdkconfig file C:/Users/Czarek/Documents/PlatformIO/Projects/Test_ESP32_S3/sdkconfig.esp32s3_120_16_8-qio_opi
-- Compiler supported targets: xtensa-esp-elf
-- App "Test_ESP32_S3" version: 1
-- Adding linker script C:/Users/Czarek/Documents/PlatformIO/Projects/Test_ESP32_S3/.pio/build/esp32s3_120_16_8-qio_opi/esp-idf/esp_system/ld/memory.ld
-- Adding linker script C:/Users/Czarek/Documents/PlatformIO/Projects/Test_ESP32_S3/.pio/build/esp32s3_120_16_8-qio_opi/esp-idf/esp_system/ld/sections.ld.in
-- Adding linker script C:/Users/Czarek/.platformio/packages/framework-espidf/components/esp_rom/esp32s3/ld/esp32s3.rom.ld
-- Adding linker script C:/Users/Czarek/.platformio/packages/framework-espidf/components/esp_rom/esp32s3/ld/esp32s3.rom.api.ld
-- Adding linker script C:/Users/Czarek/.platformio/packages/framework-espidf/components/esp_rom/esp32s3/ld/esp32s3.rom.bt_funcs.ld
-- Adding linker script C:/Users/Czarek/.platformio/packages/framework-espidf/components/esp_rom/esp32s3/ld/esp32s3.rom.libgcc.ld
-- Adding linker script C:/Users/Czarek/.platformio/packages/framework-espidf/components/esp_rom/esp32s3/ld/esp32s3.rom.wdt.ld
-- Adding linker script C:/Users/Czarek/.platformio/packages/framework-espidf/components/esp_rom/esp32s3/ld/esp32s3.rom.version.ld
-- Adding linker script C:/Users/Czarek/.platformio/packages/framework-espidf/components/esp_rom/esp32s3/ld/esp32s3.rom.newlib.ld
-- Adding linker script C:/Users/Czarek/.platformio/packages/framework-espidf/components/soc/esp32s3/ld/esp32s3.peripherals.ld
-- Configuring incomplete, errors occurred!
CMake Error at C:/Users/Czarek/.platformio/packages/framework-arduinoespressif32/CMakeLists.txt:371 (message):
esp32-arduino requires CONFIG_FREERTOS_HZ=1000 (currently 100)
========================== [FAILED] Took 7.27 seconds ==========================
[env:esp32s3_120_16_8-qio_opi]
;platform = espressif32
board = esp32s3_120_16_8-qio_opi
platform=https://github.com/pioarduino/platform-espressif32/archive/refs/tags/53.03.13.zip ; Arduino 3.1.3 IDF 5.3.2
framework = arduino, espidf
adafruit/Adafruit GFX Library@^1.12.0
adafruit/Adafruit ILI9341@^1.6.1
https://github.com/tzapu/WiFiManager
https://github.com/schreibfaul1/ESP32-audioI2S
https://github.com/ESP32Async/AsyncTCP
https://github.com/ESP32Async/ESPAsyncWebServer
cniedzi:
what is wrong here
this is wrong:
Either change the framework back to “arduino” or setup the “Arduino as ESP-IDF component” project correctly.
The question is, why did you make this change and what do you want to acheive?
Create a brand new “Arduino as ESP-IDF component” project. Let Platformio finish all tasks to setup the project properly. Then start implementing your project files.
Unfortunately, I see no option to create a new Arduino as ESP-IDF component project in my PlatformIO.
Is there any detailed manual how to do that? I was looking for it, but didn’t get anything helpful…
Unfortunately there is no option in the wizard.
Create a new, blank Arduino project.
Then edit the platformio.ini and change the framework to arduino, espidf.
Save the platformio.ini and wait until platformio setup everything.
Some steps forward, but still some issues preventing from success
Platformio.ini:
CMakeLists.txt:
cmake_minimum_required(VERSION 3.16.0)
project(Internet_Radio)
include($ENV{IDF_PATH}/tools/cmake/project.cmake)
Build errors:
Replace: CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240=y
with: CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240=y
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
CMake Warning (dev) in CMakeLists.txt:
No project() command is present. The top-level CMakeLists.txt file must
contain a literal, direct call to the project() command. Add a line of
code such as
project(ProjectName)
near the top of the file, but after cmake_minimum_required().
CMake is pretending there is a "project(Project)" command on the first
line.
This warning is for project developers. Use -Wno-dev to suppress it.
cmake_minimum_required() should be called prior to this top-level project()
call. Please see the cmake-commands(7) manual for usage documentation of
both commands.
**CMake Error in CMakeLists.txt:**
** No CMAKE_C_COMPILER could be found.**
Tell CMake where to find the compiler by setting either the environment
variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
the compiler, or to the compiler name if it is in the PATH.
** No CMAKE_CXX_COMPILER could be found.**
variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
to the compiler, or to the compiler name if it is in the PATH.
cniedzi:
code such as
line.
You should have 2 auto generated CMakeList.txt files:
./CMakeLists.txt:
project(test)
./src/CMakeLists.txt:
# This file was automatically generated for projects
# without default 'CMakeLists.txt' file.
FILE(GLOB_RECURSE app_sources ${CMAKE_SOURCE_DIR}/src/*.*)
idf_component_register(SRCS ${app_sources})
You should do this step by step! Remove these lib_deps and start with a simple “Hello World” program using Arduino as ESP-IDF component to get familiar with this.
If your Hello World program runs, start implementing your real project.
There might be some other cumbersomes waiting for you
The next error you should see is
You have to run menuconfig or edit the sdkconfig an change
to
Thanks! I’ve already found it and modified
OK, my program:
void loop()
delay(100);
gives me:
Processing esp32s3_120_16_8-qio_opi (platform: espressif32; board: esp32s3_120_16_8-qio_opi; framework: arduino, espidf)
PLATFORM: Espressif 32 (53.3.13+sha.15e5639) > ESP32-S3 16MB QIO, 8MB OPI PSRAM
Warning! Flash memory size mismatch detected. Expected 16MB, found 2MB!
Please select a proper value in your `sdkconfig.defaults` or via the `menuconfig` target!
Found 55 compatible libraries
|-- Adafruit GFX Library @ 1.12.0
|-- Adafruit ILI9341 @ 1.6.1
|-- WiFiManager @ 2.0.17+sha.b67b782
|-- ESP32-audioI2S @ 3.0.13+sha.b664b97
|-- AsyncTCP @ 3.3.6+sha.ad8b0ba
|-- ESPAsyncWebServer @ 3.7.1+sha.d5aa208
Compiling .pio\build\esp32s3_120_16_8-qio_opi\src\main.cpp.o
*** [.pio\build\esp32s3_120_16_8-qio_opi\.pio\build\esp32s3_120_16_8-qio_opi\https_server.crt.S.o] Source `.pio\build\esp32s3_120_16_8-qio_opi\https_server.crt.S' not found, needed by target `.pio\build\esp32s3_120_16_8-qio_opi\.pio\build\esp32s3_120_16_8-qio_opi\https_server.crt.S.o'.
======================================================================================= [FAILED] Took 5.02 seconds =======================================================================================
There seems to be an incompatibility with the component manager and pioarduino’s hybrid compile feature.
Please ask at pioarduino for further help.
Either open an issue or ask via their discord server.
ok. Thanks for your help and guidance.
No pioarduino issue. Since Arduino core forces (via the placed yml file) Rainmaker components install the Rainmaker setup needs to be statisfied.
add to your platformio.ini
board_build.embed_txtfiles =
managed_components/espressif__esp_insights/server_certs/https_server.crt
managed_components/espressif__esp_rainmaker/server_certs/rmaker_mqtt_server.crt
managed_components/espressif__esp_rainmaker/server_certs/rmaker_claim_service_server.crt
managed_components/espressif__esp_rainmaker/server_certs/rmaker_ota_server.crt
See example platform-espressif32/examples/espidf-arduino-littlefs at main · pioarduino/platform-espressif32 · GitHub
Sorry for the misinformation and thanks for the correction
With Jason2866’s help, this configuration should work for you:
platformio.ini
Edits in sdkconfig:
CONFIG_AUTOSTART_ARDUINO=y
Thanks! I’ve overcame this issue this way:
[env]
;platform=https://github.com/pioarduino/platform-espressif32/archive/refs/tags/53.03.13.zip
;platform = https://github.com/pioarduino/platform-espressif32.git#main
platform=espressif32
build_flags = -DCORE_DEBUG_LEVEL=3 ; 0 None, 1 Error, 2 Warn, 3 Info, 4 Debug, 5 Verbose
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
board_build.partitions = boards/default_16MB.csv ; 16MB Flash
custom_component_remove = espressif/esp_hosted
espressif/esp_wifi_remote
espressif/esp-dsp
espressif/esp32-camera
espressif/libsodium
espressif/esp-modbus
espressif/qrcode
espressif/esp_insights
espressif/esp_diag_data_store
espressif/esp_diagnostics
espressif/esp_rainmaker
espressif/rmaker_common
[env:ESP32-S3-DevKitC-1-N16R8]
board = ESP32-S3-DevKitC-1-N16R8
Currently, the only issue is I can’t get PSRAM to get worked
ESP32 Chip: ESP32-S3
Arduino Version: 3.2.0
ESP-IDF Version: 5.4.0
ARDUINO_LOOP_STACK_SIZE 8192 words (32 bit)
PSRAM SIZE 0
Regarding your board ESP32-S3-DevKitC-1-N16R8 you need to change these settings:
CONFIG_SPIRAM=y
CONFIG_SPIRAM_MODE_OCT=y
Result:
SPIRAM Memory Info:
Total Size : 8388608 B (8192.0 KB)
Free Bytes : 8385720 B (8189.2 KB)
Allocated Bytes : 576 B ( 0.6 KB)
Minimum Free Bytes: 8385720 B (8189.2 KB)
Largest Free Block: 8257536 B (8064.0 KB)
Bus Mode : OPI
cniedzi:
Please note that this is a pre release, not a stable version. See Release Arduino Pre-Release v3.2.0-RC1 based on ESP-IDF v5.4 · espressif/arduino-esp32 · GitHub
Job done Thanks!
PSRAM SIZE 8388608
audio_info: PSRAM found, inputBufferSize: 638965 bytes
audio_info: buffers freed, free Heap: 198375 bytes
audio_info: connect to: "s0.radiohost.pl" on port 8018 path "/stream"
audio_info: Connection has been established in 71 ms, free Heap: 197463 bytes
audio_info: MP3Decoder has been initialized, free Heap: 189007 bytes , free stack 4408 DWORDs
audio_info: stream ready
audio_info: syncword found at pos 0
audio_info: MPEG-2.5, Layer I
audio_info: Channels: 2
audio_info: SampleRate: 44100
audio_info: BitsPerSample: 16
audio_info: BitRate: 256000
audio_info: StreamTitle='Fancy - Flames Of Love (Extended Version)
