How to use ESP-IDF stable version
ESP.getSdkVersion() is reporting v3.3-beta1-179-ge931fe9f5-dirty
with the following setting
Is it ok? How can I move to stable version 3.1.3?
Thanks
alf45tar
First of all, I’m confused… AFAIK arduino framework != ESP-IDF? But if you have the current version of the espressif32 platformio platform files (v1.7.0), then per this announcement, you have access to v3.1.3 of the ESP-IDF… or if using the arduino framework, whatever ESP-IDF version it is using…
Yes this OK, since according to Releases · platformio/platform-espressif32 · GitHub the latest Arduino core is 1.0.1 and in their release notes, they state which Update IDF to e931fe9 corresponds to ESP-IDF at the state GitHub - espressif/esp-idf at e931fe9f578a7ce6b6aa28261750bb1344509e15. So it’s OK that you have a “v3.3-beta” version, this is what the released Arduino core uses.
If you want to use ESP-IDF, state framework = espidf and make sure to update your platforms (pio platform update), this will give you a ESP-IDF 3.1.3 environment.
