I’ve a custom board.json containing a key/value “f_cpu”: 48000000. I would like to set a define in platformio.ini when this board is selected to “-DF_CPU=48000000”.
Is it possible to do so without an extra script ? If yes, how ?
Else, what’s the cleanest way to do it with an extra script ?
As referenced for any environment that uses platform = atmelavr it already does the -D F_CPU=.. macro. Just for some others that may not be the default – if you can say which exactly, that can be added as an improvement in the existing cores.
