Greetings!
I am running PlatformIO on Linux Mint 20. Trying to upload code to a SparkFun Arduino Pro Mini 328 using SparkFun FT231X programmer. Following the FTDI chip page I set the upload_protocol in the platformio.ini like so:
[env:sparkfun_promicro8]
board = sparkfun_promicro8
upload_protocol = ftdi
But when trying to upload I get:
AVAILABLE: ftdi
CURRENT: upload_protocol = ftdi
Looking for upload port...
Auto-detected: /dev/ttyUSB0
Forcing reset using 1200bps open/close on port /dev/ttyUSB0
Waiting for the new upload port...
Uploading .pio/build/sparkfun_promicro8/firmware.hex
avrdude: Can't find programmer id "ftdi"
Valid programmers are:
and a whole list of programmers. I switched to avrftdi, but things didn’t get much better:
AVAILABLE: avrftdi
CURRENT: upload_protocol = avrftdi
avrdude: Error: no libftdi or libusb support. Install libftdi1/libusb-1.0 or libftdi/libusb and run configure/make again.
avrdude done. Thank you.
*** [upload] Error 1
How do I make the upload work?
Please note:
- Uploading works fine from the Arduino IDE. No change in setup.
- PlatformIO serial monitor works. Both ways - input and output. The FT231XS is known and working.
Cheers!
tjk
