How to update Unity to v2.6.0
I just noticed that the PlatformIO registry has v2.5.2 which is now older than the latest v2.6.0 GitHub release.
How do I request an update on the registry? There’s a bug that got fixed in the newer release.
You can update to any particular version as described here
The default behavior is to include this version
but the PIO registery hasn’t been updated for a long time, only sporting 2.5.2 instead of 2.6.0:
https://registry.platformio.org/libraries/throwtheswitch/Unity/versions
In this case, you need to follow the technique for a custom Unity library:
https://docs.platformio.org/en/latest/advanced/unit-testing/frameworks/custom/examples/custom_unity_library.html#unit-testing-frameworks-custom-examples-unity-library
but instead use a custom runner of
from platformio.public import UnityTestRunner
class CustomTestRunner(UnityTestRunner):
    # Use custom version
    EXTRA_LIB_DEPS = ["https://github.com/ThrowTheSwitch/Unity/archive/refs/tags/v2.6.0.zip"]
Proof:
> pio test -vvv -e native
Collected 2 tests (test_desktop, test_embedded)
Processing test_desktop in native environment
-------------------------------Building...
Found 2 compatible libraries
|-- Unity @ 2.6.0 (License: MIT, URI: https://github.com/ThrowTheSwitch/Unity/archive/refs/tags/v2.6.0.zip, Path: C:\Users\Max\temp\unity_26\.pio\libdeps\native\Unity)
Building in test mode
Testing...
test\test_desktop\test_main.cpp:19:simple_test:PASS
1 Tests 0 Failures 0 Ignored
OK
-----------------test_desktop [PASSED] Took 1.17 seconds -----------
See
CC @ivankravets for updating https://registry.platformio.org/libraries/throwtheswitch/Unity/versions to latest 2.6.0 release, this is already tracked in
Thanks a lot for your help!
Implemented in
Please re-test with pio upgrade --dev.
