About a month ago there was an update to the Wire library to include timeouts.
I didn’t see an option to update the wire library and I am not sure how can I use this much needed and wanted updates (Timeout handling).
If it matters I am using the following specs in my platfrom.ini:
Using the Adafruit_SSD1306 with a 128 x 32 display, just did a demo, with the text updating a few times a second, works fine for just over an hour, then the display goes black - the program is still running (output to serial is fine).
I tried setting “Wire.setTimeout(1000);”
but still ‘dies’, my library doesn’t have the “setWireTimeout”
All the references seem to talk about a ‘hangup’, but my code keeps running, just the display is black ! ? Perhaps it’s a different fault ?
The Adafruit libraries reference the wire lib, so without re-writing them all, I could patch in another copy easily.
You may want to open an issue about this in the Arduino core implementation you’re using, or the Adafruit-SSD1306 library, they can help you better.
It might also pay off to get a logic analyzer (there are very cheap Salae clone ones) to continously capture the I2C bus with it, to see what exactly is going on on the wires.
