How to supress debug-messages from Serial Monitor?
Hi!
I just changed from Arduino-IDE to PlatformIO. I can compile, upload and run my program, but my serial console is flooded with something like
%d,%d>, passive=%d
ord is empty
 aid = %d, channel %d, %s, bssid = %02x:%02x:%02x:%02x:%02x:%02x
M�@��@M�@M�@M�@��@M�@��@M�@M�@2�@M�@M�@M�@M�@M�@M�@M�@M�@��@M�@A�@2�@��@��@��@M�@2�@M�@M�@M�@M�@��@2�@��@M�@M�@��@M�@2�@M�@M�@2�@�@i�@��@F�@z�@��@��@E�@��@E�@�@�@E�@��@��@��@��@��@��@��@p�@��@��@��@��@��@��@��@��@ �@&�@&�@&�@&�@&�@&�@&�@&�@&�@��@��@��@��@��@��@��@�
@��@��@��@��@��@��@��@��@��@��@��@��@��@��@��@��@��@U�@��@M�@��@��@j�@��@��@��@��@��@��@��@��@��@��@��@��@��@��@��@Y�@��@��@��@x�@��@��@��@y�@��@��@U�@:�@R�@��@��@#�@��@:�@0000000000000000                *@m�@r�@��@�@�@�@�@T@��@>@I@T@T@T@��@��@��@��@��@��@��@I@��@�
�@��@3@��@I@��@��@��@��@��@��@��@��@��@��@��@T@��@��@��@T@T@T@��@��@��@��@��@��@3@��@3@��@��@3@��@��@��@��@��@�
d(@d(@d(@d(@d(@d(@d(@d(@
d@in@in@T@in@in@in@in@in@in@in@in@in@in@8W@!X@in@in@in@�V@!X@1W@in@W@in@}[@e_@c@1W@in@�c@�S@�d@in@in@�h@in@�S@0000000000000000
-2s %-3s %-5s %-11s %-10s %-8s %-8s
0.0W 0.00V
Its very hard for me to find my own printed debugging messages. How can i supress this “internal” messages?
I´ve tried
build_flags = -DCORE_DEBUG_LEVEL=0
in platformio.ini
and
#define LOG_LOCAL_LEVEL ESP_LOG_ERROR
in my code.
unfortunally without success.
When i build with arduino-ide there are only my own messages visible. Is that even possible with platformio?
Thanks!
The output looks extremely broken with format strings being there. Also, debug level 0 (none) is already default.
Can you please
  • show your platformio.ini
  • show the code
  • show the version of the ESP32 core in the Arduino IDE boards manager
[env:heltec_wifi_kit_32]
board = heltec_wifi_kit_32
    lorol/LittleFS_esp32@^1.0.6
    olikraus/U8g2@^2.28.8
    wollewald/INA226_WE@^1.2.3
    adafruit/Adafruit DPS310@^1.1.1
monitor_filters = direct, esp32_exception_decoder
[platformio]
description = BafangTQ2 von Arduino
the full code is to big.
First lines:
You mean that?
I am too stupid. Just found out i had the wrong configuration active!
