I’m directly programming an atmega328p (RC osc, 8 mhz, clkdiv8, so 1 mhz) using and Arduino Nano as an ISP programmer. Specifically, I’m putting a blank (from Mouser) 328 into a breakout board, and attaching the ISP pins, with zero supporting circuitry.
I’m using the 328p8m
board.
This almost works – the flash needs to be erased before programming, but it looks like the ‘atmelavr’ platform builder script is hard-coded to use the -D
(don’t erase flash) avrdude flag, for most upload protocols.
Is this something that can be overridden in a board JSON file, or is a custom builder script needed? Or something else?
This is working – no longer has the -D flag.
However, looks like the “program” target does not support auto-detection of the serial port, nor does it support the “wildcard” option for the upload_port
variable:
In builder/main.py
line 256 it adds BeforeUpload
to the list of commands, but if you look at BeforeUpload
, it will immediately return for the program
target.
Not sure if this behavior is intentional, but the docs don’t mention that these things won’t work when using the program
target.
Would a PR that simply moves these lines:
env.Append(UPLOADERFLAGS=["-P", '"$UPLOAD_PORT"'])```
Above the check for the `program` target be accepted?
Yes, that works fine, if you want to manually set the port. It would be nice if the auto-detect of the port worked for the program
target.
I’m referring to this part of the documentation:
If upload_port isn’t specified, then PlatformIO will try to detect it automatically.
If it’s not supported for the program
target, that’s fine – need to update the documentation. If it is supported, then it should work.
[env:328p8m]
board = 328p8m
board_f_cpu = 1000000
# arduino as ISP
#upload_port = /dev/ttyUSB0
upload_speed = 57600
upload_protocol = arduinoisp
upload_protocol = stk500v1
upload_flags = -b$UPLOAD_SPEED
Results in this:
avrdude: ser_open(): can't open device "com1": No such file or directory
Actual port is /dev/ttyUSB0
– auto-detect of this port does work for the upload
target, but upload
fails because of the -D
flag.
Take a look at
Just overwrite UPLOADHEXCMD with '$UPLOADER $UPLOADERFLAGS -U flash:w:$SOURCES:i'
and use upload
target instead of program
