How to select the proper library with a #ifdef directive
Hello
I have to libs with the same primitive names. I want to select one of the two depending upon a #define variable.
It does not work as I expect. Could you help me to find the right way ?
Here is the principle :
//#define USE_FOO
#define USE_BAR
#ifdef USE_FOO
#include "foo.h"
#ifdef USE_BAR
#include "bar.h"
void app_main()
    hello();
Here are the libs
bar.h
#pragma once
void hello();
bar.c :
#include "bar.h"
#include  <stdio.h>
void hello()
    printf("\nhello from bar\n");
now foo.h (same as bar.h)
#pragma once
void hello();
foo.c ()
#include "foo.h"
#include  <stdio.h>
void hello()
    printf("\nhello from foo\n");
The problem is whatever I select USE_FOO or USE_BAR
the result is always hello from foo at the execution level
How to select the proper file during the link process?
Thank you for your help.
