I would like to embed my web site inside PROGMEM for my platformio project.
In order to do that, I u se gulp script. My script is okay and works well.
I would like to run my gulp script at each build using pre-script.
The main problem I encounter is that the gulp command has to be executed in subfolder of my platformio project.
Here is extract of my platformio.ini
extra_scripts =
pre:pre_extra_script.py
post:extra_script.py
Here is pre_extra_script.py
Import("env")
# access to global build environment
print(env)
# Build actions
print("BEFORE BUILD----------------------")
print("Running gulp")
env.Execute("web/gulp")
The problem comes from env.Execute command which doesn’t works. I don’t know how to run “gulp” command in “./web” folder.
How I can ask to env.Execute commande to run gulp command inside web subfolder ?
