name=M5ez
version=2.3.0
author=Rop Gonggrijp
maintainer=Rop Gonggrijp
sentence=Complete interface builder for the M5Stack, an ESP32 based mini tinker-computer
paragraph=See more on https://github.com/M5ez/M5ez
category=Display
url=https://github.com/M5ez/M5ez
architectures=esp32
includes=M5ez.h
depends=ezTime, M5Stack
This causes lots of redefined errors. I don’t have such a problem in Arduino IDE. I’m using VS + PlatformIO.
Looks like you have leftovers from when you started developing the libraries or used a different M5Stack. Just delete the .pio folder of the project and hit “Build” again to get a clean build.
Note that I had to add lib_ldf_mode = deep to the platformio.ini to make PlatformIO correctly recognize the dependencies between the libraries, otherwise it would get very confused with all the #ifdef #include <..> constructs. Then, compiling a src/main.cpp of
That’s because when you loaded the code I’d already updated my M5ez fork and removed M5Stack from the dependency list (see commit removed wifi · dizcza/M5ez@cf76a31 · GitHub). Sorry for that.
In order to reproduce the issue, please change the lib deps to the following:
