I’m using the newest PlatformIO and VS Code on Ubuntu 22.04.2. I have a Hezhou CORE ESP32 core board (https://wiki.luatos.com/chips/esp32c3/board.html ), which comes with Lua interpreter:
I was able to upload a simple blinky sketch (C++) with Arduino IDE 2.1 selecting Adafruit QtPy board and these settings:
I would like to program this board with PlatformIO. What would be a platformio.ini file with the settings from screen capture above?
Will uploading the binaries created by PlatformIO remove Lua firmware, so I can program the board in C++ like many other ESP32 boards?
I just found Using Luatos ESP32C3 . Will test and post the results.
It seems that this board is supported as Deneyap Kart G , but freshly updated PlatformIO v6.1.7 responds to:
[env:deneyapkartg]
board = deneyapkartg
with
Resolving deneyapkartg dependencies...
Error: Unknown board ID 'deneyapkartg'
The documentation version is 6.1.8a1. Do I have to wait for PlatformIO v6.1.8 to get this board ID recognized?
I copied deneyapkartg.json file from documentation to boards folder:
but the project fails to build now:
Processing deneyapkartg (platform: espressif32; board: deneyapkartg; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/deneyapkartg.html
PLATFORM: Espressif 32 (4.4.0) > Deneyap Kart G
HARDWARE: ESP32C3 160MHz, 320KB RAM, 4MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 @ 3.20003.0 (2.0.3)
- tool-mkfatfs @ 2.0.1
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch3
Found 32 compatible libraries
Compiling .pio/build/deneyapkartg/src/main.cpp.o
Generating partitions .pio/build/deneyapkartg/partitions.bin
Archiving .pio/build/deneyapkartg/libFrameworkArduinoVariant.a
Indexing .pio/build/deneyapkartg/libFrameworkArduinoVariant.a
Compiling .pio/build/deneyapkartg/FrameworkArduino/Esp.cpp.o
Compiling .pio/build/deneyapkartg/FrameworkArduino/FirmwareMSC.cpp.o
Compiling .pio/build/deneyapkartg/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pio/build/deneyapkartg/FrameworkArduino/HWCDC.cpp.o
Compiling .pio/build/deneyapkartg/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pio/build/deneyapkartg/FrameworkArduino/IPAddress.cpp.o
Compiling .pio/build/deneyapkartg/FrameworkArduino/IPv6Address.cpp.o
Compiling .pio/build/deneyapkartg/FrameworkArduino/MD5Builder.cpp.o
/home/paul/.platformio/packages/framework-arduinoespressif32/cores/esp32/HardwareSerial.cpp:6:10: fatal error: pins_arduino.h: No such file or directory
How to fix it?
Then your Espressif32 platform is not new enough.That’s why it doesn’t have the latest Arduino-ESP32 core too and throws you a missing pins_arduino.h error, because variants/deneyapkartg is not there.
Please:
Remove deneyapkartg.json from your local project
Open a PlatformIO core CLI → pio pkg update -g -p espressif32
Rebiuld while still referencing the above board name in the platformio.ini.
Thank you, it builds now. BTW, the log shows a dramatic version update:
Platform Manager: Updating espressif32 @ 4.4.0
Platform Manager: Removing espressif32 @ 4.4.0
Platform Manager: espressif32@4.4.0 has been removed!
Platform Manager: Installing platformio/espressif32 @ 6.2.0
I’ve been relying on VSCode auto updates. Should I update manually in the future, so I don’t fall that far behind?
I think I remember reading some time ago that auto-updating platforms were turned off because people couldn’t stand having their projects auto-broken with version increases. There’s always a losing side with this.
deneyapkartg is a wrong board specification - it uses ESP32C3 with 4MB of embedded Flash vs. Lua board with 4MB of external Flash. The boot fails. I can now program with this configuration:
board_build.mcu = esp32c3
but it doesn’t provide serial communication through USB. I tried:
build_flags = -DARDUINO_USB_CDC_ON_BOOT=1
but it makes Serial class undefined:
src/main.cpp: In function 'void setup()':
src/main.cpp:9:3: error: 'Serial' was not declared in this scope
It works fine with Arduino IDE.
Do you mean that PlatformIO Core auto-updates, which I witnessed, but underlying SDKs do not?
That’s uhm, an odd combination / rework. I don’t think that’s possible like that. Can you just try
board = lolin_c3_mini
instead?
Exactly.
maxgerhardt:
Can you just try
It fails to boot after upload. Lolin uses ESP32C3 with embedded Flash. I think that configuration has to specify external Flash for correct boot.
Here is a configuration, which works:
[env:lolin_c3_mini]
board_build.flash_mode = dio
ray111
June 5, 2023, 8:23am
13
Is the version updated and compatible?
Which version you are referring to? PlatformIO Core and Espressif SDK are current.
