How to program AtMega1284P using AVRISP mkII on macOS?
Hi guys, here is my platformio.ini
[plaformio]
env_default = atmega1284
[env:atmega1284]
board = 1284p8m
board_build.mcu = atmega1284p
board_build.f_cpu = 8000000L
lib_extra_dirs = ~/Documents/Arduino/libraries
extra_scripts = dist.py
# upload_port=/dev/cu.wchusbserial1410
upload_protocol = stk500v2
; each flag in a new line
upload_flags =
    -Pusb
upload_port = usb
My schematic looks like this but I used 8 MHz crystal and FT232 is not installed yet.
And information about the programmer
AVRISP mkII:
  Product ID:	0x2104
  Vendor ID:	0x03eb  (Atmel Corporation)
  Version:	2.00
  Serial Number:	001D2C991679
  Speed:	Up to 12 Mb/sec
  Manufacturer:	ATMEL
  Location ID:	0x14100000 / 27
  Current Available (mA):	500
  Extra Operating Current (mA):	0
This is compiler/avrdude output:
/Applications/CLion.app/Contents/bin/cmake/mac/bin/cmake --build /Users/zoonman/Projects/cpp/nanodds/cmake-build-debug --target PLATFORMIO_UPLOAD -- -j 4
Processing atmega1284 (framework: arduino; platform: atmelavr; board: 1284p8m)
PLATFORM: Atmel AVR > Microduino Core+ (ATmega1284P@8M,3.3V)
SYSTEM: ATMEGA1284P 8MHz 16KB RAM (127KB Flash)
Collected 34 compatible libraries
|-- <Adafruit ST7735 and ST7789 Library> 1.2.4
|   |-- <SPI> 1.0
|   |-- <Adafruit GFX Library> 1.2.9
|   |   |-- <SPI> 1.0
|-- <Etherkit Si5351> 2.1.2
|   |-- <Wire> 1.0
|   |-- <SPI> 1.0
Checking size .pioenvs/atmega1284/firmware.elf
DATA:    [=         ]   7.2% (used 1185 bytes from 16384 bytes)
PROGRAM: [==        ]  21.9% (used 28536 bytes from 130048 bytes)
AVAILABLE: stk500v2
CURRENT: upload_protocol = stk500v2
Looking for upload port...
Use manually specified: usb
*** [upload] could not open port usb: [Errno 2] No such file or directory: 'usb'
Programmer connected through J3.
I am trying to figure out how to specify USB port on macOS Mojave.
After some extensive googling I have the following:
avrdude -p m1284p -c stk500v2 -P usb:16:79 -v
avrdude: Version 6.3, compiled on Dec 20 2018 at 23:10:28
         System wide configuration file is "/opt/local/etc/avrdude.conf"
         User configuration file is "/Users/zoonman/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb:16:79
         Using Programmer              : stk500v2
avrdude: usbdev_open(): Found AVRISP mkII, serno: 001D2C991679
         AVR Part                      : ATmega1284P
         Chip Erase delay              : 55000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10   128    0 no       4096    8      0  9000  9000 0xff 0xff
           flash         65    10   256    0 yes    131072  256    512  4500  4500 0xff 0xff
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel STK500 Version 2.x firmware
         Programmer Model: AVRISP mkII
         Hardware Version: 1
         Firmware Version Master : 1.24
         Vtarget         : 4.9 V
         SCK period      : 4.00 us
avrdude: stk500v2_command(): command failed
avrdude: stk500v2_program_enable(): bad AVRISPmkII connection status: Unknown status 0x00
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
I had to install avrdude using MacPorts and started running it from command line.
Because I don’t have FT232 installed I suspect it cannot program the controller because RESET line is not pulled up to +5V.
Should I install some resistor and check?
It seems works from time to time but I suspect I have loose connection somewhere.
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 1
         Vtarget         : 4.9 V
avrdude: Device signature = 0x1e9705 (probably m1284p)
avrdude: safemode: hfuse reads as 99
avrdude: safemode: efuse reads as FF
avrdude: safemode: Fuses OK (E:FF, H:99, L:62)
Still can’t figure out how to specify usb port for platformio.
upload_protocol = avrsip2
upload_flags =
    -v
    -Pusb:16:79
upload_port = usb:16:79
Doesn’t work for me.
Use the -v option (e.g. pio run -v -t upload) to see what commandline is executed for the upload so that you can adjust your upload_flags to match your previous successful run.
Not really showing me anything special.
<lambda>(["upload"], [".pioenvs/atmega1284/firmware.hex"])
AVAILABLE: avrsip2
CURRENT: upload_protocol = avrsip2
BeforeUpload(["upload"], [".pioenvs/atmega1284/firmware.hex"])
Use manually specified: usb:16:79
*** [upload] could not open port usb:16:79: [Errno 2] No such file or directory: 'usb:16:79'
After enormous amount of research I found GitHub - maniacbug/mighty-1284p: Mighty 1284P Platform for Arduino bootloader. It seems works but has a glitch for progmem access. All my PSTR constants have wrong address.
For programming I am using avrdude.
avrdude -p m1284p -c avrisp2 -P usb:16:79 -e -U flash:w:atmega1284/firmware.hex -v
Looks like platformio tool doesn’t work properly with AVRISPMkII.
I am using an avrispmk2 and it works pretty well.
Try upload_protocol/-c “avrispmkii” or “wiring”.
I tried. Didn’t work for me. Sorry.
I figured out that 3.3V power supply supposed to be removed from LCD and after programmer starts working flawlessly.
Looks like ST7735 SDA holds MOSI and it messes up programmer.
have you tried program target instead of upload?
pio run -t program
See Atmel AVR — PlatformIO latest documentation
Thank you very much, Ivan! :+1:
It did work for me but I had to set
upload_protocol = avrispmkII
instead of avrisp2.
