Hi there,
I am trying to compile a project with multi src file in multi dir. (I need add Core/Src
, USB_DEVICE/App
, and USB_DEVICE/Target
to the project, but now I only add the first one by src_dir
I don’t know how to add all of them to the project.
Could you help me?
Thanks a lot!
I’d point src_dir
to a common parent directory in [platformio]
, and then add multiple filters to the build_src_filter
setting in [env:...]
. Or else perhaps add multiple filters using relative +<../../etc...>
specifications.
See src_dir — PlatformIO latest documentation
and build_src_filter — PlatformIO latest documentation
Hi @jcw
Thanks for your reply.
I already try the build_src_filter
, but it seems not working.
I check the document about build_src_filter
This option allows one to specify which source files should be included or excluded from src_dir for a build process.
According to the doc, I think this item’s config range is just the file in src_dir
