I’m building an arduino project, and I already have some library installed via library manager. This lib works fine when I call it.
However, I’m trying to customize this lib in a particular project’s lib folder. I have copied the files to the folder:
$PROJECT_HOME/lib/MFRC522/MFRC522.h
$PROJECT_HOME/lib/MFRC522/MFRC522.cpp
then customized them, cleaned the project and compiled, however when I compile, I see errors coming from what looks like the platformio shared version of the lib, not the custom one in my lib folder inside my project.
How to keep platformio from compiling the shared lib, and instead use the local lib?
> Executing task in folder MFRC522-demo: platformio run <
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR > Arduino Uno
HARDWARE: ATMEGA328P 16MHz 2KB RAM (31.50KB Flash)
Converting DumpInfo.ino
Collected 13 compatible libraries
|-- <MFRC522>
| |-- <MFRC522> 1.4.3
| | |-- <SPI> 1.0
| |-- <SPI> 1.0
|-- <SPI> 1.0
Compiling .pioenvs/uno/src/DumpInfo.ino.cpp.o
Compiling .pioenvs/uno/lib2d9/SPI/SPI.cpp.o
Compiling .pioenvs/uno/libc67/MFRC522_ID63/MFRC522.cpp.o
Compiling .pioenvs/uno/libc67/MFRC522_ID63/MFRC522Extended.cpp.o
Archiving .pioenvs/uno/lib2d9/libSPI.a
Compiling .pioenvs/uno/libcc2/MFRC522/MFRC522.cpp.o
/Users/jens/.platformio/lib/MFRC522_ID63/src/MFRC522.cpp: In member function 'bool MFRC522::MIFARE_SetUid(byte*, byte, bool)':
/Users/jens/.platformio/lib/MFRC522_ID63/src/MFRC522.cpp:1852:7: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
if (!MIFARE_OpenUidBackdoor(logErrors)) {
/Users/jens/.platformio/lib/MFRC522_ID63/src/MFRC522.cpp:1708:6: note: declared here
bool MFRC522::MIFARE_OpenUidBackdoor(bool logErrors) {
/Users/jens/.platformio/lib/MFRC522_ID63/src/MFRC522.cpp:1852:39: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
/Users/jens/.platformio/lib/MFRC522_ID63/src/MFRC522.cpp: In member function 'bool MFRC522::MIFARE_UnbrickUidSector(bool)':
/Users/jens/.platformio/lib/MFRC522_ID63/src/MFRC522.cpp:1881:2: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
MIFARE_OpenUidBackdoor(logErrors);
/Users/jens/.platformio/lib/MFRC522_ID63/src/MFRC522.cpp:1881:34: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
In file included from /Users/jens/.platformio/lib/MFRC522_ID63/src/MFRC522Extended.cpp:8:0:
/Users/jens/.platformio/lib/MFRC522_ID63/src/MFRC522Extended.h: In constructor 'MFRC522Extended::MFRC522Extended(uint8_t)':
/Users/jens/.platformio/lib/MFRC522_ID63/src/MFRC522Extended.h:81:44: warning: 'MFRC522::MFRC522(byte)' is deprecated: use MFRC522(byte chipSelectPin, byte resetPowerDownPin) [-Wdeprecated-declarations]
MFRC522Extended(uint8_t rst) : MFRC522(rst) {};
In file included from /Users/jens/.platformio/lib/MFRC522_ID63/src/MFRC522Extended.h:10:0,
/Users/jens/.platformio/lib/MFRC522_ID63/src/MFRC522.h:340:2: note: declared here
MFRC522(byte resetPowerDownPin);
Indexing .pioenvs/uno/lib2d9/libSPI.a
lib/MFRC522/MFRC522.cpp: In member function 'MFRC522::StatusCode MFRC522::NTAG_Read_Counter(uint32_t*)':
lib/MFRC522/MFRC522.cpp:1244:25: warning: left shift count >= width of type [-Wshift-count-overflow]
Archiving .pioenvs/uno/libFrameworkArduinoVariant.a
counter = buffer[0] << 16 | buffer[1] << 8 | buffer[2];
lib/MFRC522/MFRC522.cpp:1245:9: warning: invalid conversion from 'uint32_t {aka long unsigned int}' to 'MFRC522::StatusCode' [-fpermissive]
return counter;
lib/MFRC522/MFRC522.cpp: In member function 'bool MFRC522::MIFARE_SetUid(byte*, byte, bool)':
lib/MFRC522/MFRC522.cpp:1880:7: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
lib/MFRC522/MFRC522.cpp:1736:6: note: declared here
lib/MFRC522/MFRC522.cpp:1880:39: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
lib/MFRC522/MFRC522.cpp: In member function 'bool MFRC522::MIFARE_UnbrickUidSector(bool)':
lib/MFRC522/MFRC522.cpp:1909:2: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
lib/MFRC522/MFRC522.cpp:1909:34: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
Indexing .pioenvs/uno/libFrameworkArduinoVariant.a
Compiling .pioenvs/uno/FrameworkArduino/CDC.cpp.o
Compiling .pioenvs/uno/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pioenvs/uno/FrameworkArduino/HardwareSerial0.cpp.o
Archiving .pioenvs/uno/libc67/libMFRC522_ID63.a
Archiving .pioenvs/uno/libcc2/libMFRC522.a
Indexing .pioenvs/uno/libc67/libMFRC522_ID63.a
Compiling .pioenvs/uno/FrameworkArduino/HardwareSerial1.cpp.o
Indexing .pioenvs/uno/libcc2/libMFRC522.a
Compiling .pioenvs/uno/FrameworkArduino/HardwareSerial2.cpp.o
Compiling .pioenvs/uno/FrameworkArduino/HardwareSerial3.cpp.o
Compiling .pioenvs/uno/FrameworkArduino/IPAddress.cpp.o
Compiling .pioenvs/uno/FrameworkArduino/PluggableUSB.cpp.o
Compiling .pioenvs/uno/FrameworkArduino/Print.cpp.o
Compiling .pioenvs/uno/FrameworkArduino/Stream.cpp.o
Compiling .pioenvs/uno/FrameworkArduino/Tone.cpp.o
Compiling .pioenvs/uno/FrameworkArduino/USBCore.cpp.o
Compiling .pioenvs/uno/FrameworkArduino/WInterrupts.c.o
Compiling .pioenvs/uno/FrameworkArduino/WMath.cpp.o
Compiling .pioenvs/uno/FrameworkArduino/WString.cpp.o
Compiling .pioenvs/uno/FrameworkArduino/abi.cpp.o
Compiling .pioenvs/uno/FrameworkArduino/hooks.c.o
Compiling .pioenvs/uno/FrameworkArduino/main.cpp.o
Compiling .pioenvs/uno/FrameworkArduino/new.cpp.o
Compiling .pioenvs/uno/FrameworkArduino/wiring.c.o
Compiling .pioenvs/uno/FrameworkArduino/wiring_analog.c.o
Compiling .pioenvs/uno/FrameworkArduino/wiring_digital.c.o
Compiling .pioenvs/uno/FrameworkArduino/wiring_pulse.S.o
Compiling .pioenvs/uno/FrameworkArduino/wiring_pulse.c.o
Compiling .pioenvs/uno/FrameworkArduino/wiring_shift.c.o
Archiving .pioenvs/uno/libFrameworkArduino.a
Indexing .pioenvs/uno/libFrameworkArduino.a
Linking .pioenvs/uno/firmware.elf
MFRC522.cpp.o (symbol from plugin): In function `MFRC522::PICC_ReadCardSerial()':
(.text+0x0): multiple definition of `MFRC522::PICC_ReadCardSerial()'
MFRC522.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `MFRC522::MFRC522()'
(.text+0x0): multiple definition of `MFRC522::MFRC522(unsigned char)'
(.text+0x0): multiple definition of `MFRC522::MFRC522(unsigned char, unsigned char)'
(.text+0x0): multiple definition of `MFRC522::PCD_WriteRegister(MFRC522::PCD_Register, unsigned char)'
(.text+0x0): multiple definition of `MFRC522::PCD_WriteRegister(MFRC522::PCD_Register, unsigned char, unsigned char*)'
(.text+0x0): multiple definition of `MFRC522::PCD_ReadRegister(MFRC522::PCD_Register)'
(.text+0x0): multiple definition of `MFRC522::PCD_ReadRegister(MFRC522::PCD_Register, unsigned char, unsigned char*, unsigned char)'
(.text+0x0): multiple definition of `MFRC522::PCD_SetRegisterBitMask(MFRC522::PCD_Register, unsigned char)'
(.text+0x0): multiple definition of `MFRC522::PCD_ClearRegisterBitMask(MFRC522::PCD_Register, unsigned char)'
(.text+0x0): multiple definition of `MFRC522::PCD_CalculateCRC(unsigned char*, unsigned char, unsigned char*)'
(.text+0x0): multiple definition of `MFRC522::PCD_Reset()'
(.text+0x0): multiple definition of `MFRC522::PCD_AntennaOn()'
(.text+0x0): multiple definition of `MFRC522::PCD_Init()'
(.text+0x0): multiple definition of `MFRC522::PCD_Init(unsigned char, unsigned char)'
(.text+0x0): multiple definition of `MFRC522::PCD_Init(unsigned char)'
(.text+0x0): multiple definition of `MFRC522::PCD_AntennaOff()'
(.text+0x0): multiple definition of `MFRC522::PCD_GetAntennaGain()'
(.text+0x0): multiple definition of `MFRC522::PCD_SetAntennaGain(unsigned char)'
(.text+0x0): multiple definition of `MFRC522::PCD_PerformSelfTest()'
(.text+0x0): multiple definition of `MFRC522::PCD_SoftPowerDown()'
(.text+0x0): multiple definition of `MFRC522::PCD_SoftPowerUp()'
(.text+0x0): multiple definition of `MFRC522::PCD_CommunicateWithPICC(unsigned char, unsigned char, unsigned char*, unsigned char, unsigned char*, unsigned char*, unsigned char*, unsigned char, bool)'
(.text+0x0): multiple definition of `MFRC522::PCD_TransceiveData(unsigned char*, unsigned char, unsigned char*, unsigned char*, unsigned char*, unsigned char, bool)'
(.text+0x0): multiple definition of `MFRC522::PICC_Select(MFRC522::Uid*, unsigned char)'
(.text+0x0): multiple definition of `MFRC522::PICC_REQA_or_WUPA(unsigned char, unsigned char*, unsigned char*)'
(.text+0x0): multiple definition of `MFRC522::PICC_RequestA(unsigned char*, unsigned char*)'
(.text+0x0): multiple definition of `MFRC522::PICC_IsNewCardPresent()'
(.text+0x0): multiple definition of `MFRC522::PICC_WakeupA(unsigned char*, unsigned char*)'
(.text+0x0): multiple definition of `MFRC522::PICC_HaltA()'
(.text+0x0): multiple definition of `MFRC522::PCD_Authenticate(unsigned char, unsigned char, MFRC522::MIFARE_Key*, MFRC522::Uid*)'
(.text+0x0): multiple definition of `MFRC522::PCD_StopCrypto1()'
(.text+0x0): multiple definition of `MFRC522::MIFARE_Read(unsigned char, unsigned char*, unsigned char*)'
(.text+0x0): multiple definition of `MFRC522::MIFARE_Ultralight_Write(unsigned char, unsigned char*, unsigned char)'
(.text+0x0): multiple definition of `MFRC522::MIFARE_TwoStepHelper(unsigned char, unsigned char, long)'
(.text+0x0): multiple definition of `MFRC522::MIFARE_Decrement(unsigned char, long)'
(.text+0x0): multiple definition of `MFRC522::MIFARE_Increment(unsigned char, long)'
(.text+0x0): multiple definition of `MFRC522::MIFARE_Restore(unsigned char)'
(.text+0x0): multiple definition of `MFRC522::MIFARE_Transfer(unsigned char)'
(.text+0x0): multiple definition of `MFRC522::MIFARE_GetValue(unsigned char, long*)'
(.text+0x0): multiple definition of `MFRC522::PCD_NTAG216_AUTH(unsigned char*, unsigned char*)'
(.text+0x0): multiple definition of `MFRC522::PCD_MIFARE_Transceive(unsigned char*, unsigned char, bool)'
(.text+0x0): multiple definition of `MFRC522::MIFARE_Write(unsigned char, unsigned char*, unsigned char)'
(.text+0x0): multiple definition of `MFRC522::MIFARE_SetValue(unsigned char, long)'
(.text+0x0): multiple definition of `MFRC522::GetStatusCodeName(MFRC522::StatusCode)'
(.text+0x0): multiple definition of `MFRC522::PICC_GetType(unsigned char)'
(.text+0x0): multiple definition of `MFRC522::PICC_GetTypeName(MFRC522::PICC_Type)'
(.text+0x0): multiple definition of `MFRC522::PCD_DumpVersionToSerial()'
(.text+0x0): multiple definition of `MFRC522::PICC_DumpDetailsToSerial(MFRC522::Uid*)'
(.text+0x0): multiple definition of `MFRC522::PICC_DumpMifareClassicSectorToSerial(MFRC522::Uid*, MFRC522::MIFARE_Key*, unsigned char)'
(.text+0x0): multiple definition of `MFRC522::PICC_DumpMifareClassicToSerial(MFRC522::Uid*, MFRC522::PICC_Type, MFRC522::MIFARE_Key*)'
(.text+0x0): multiple definition of `MFRC522::PICC_DumpMifareUltralightToSerial()'
(.text+0x0): multiple definition of `MFRC522::PICC_DumpToSerial(MFRC522::Uid*)'
(.text+0x0): multiple definition of `MFRC522::MIFARE_SetAccessBits(unsigned char*, unsigned char, unsigned char, unsigned char, unsigned char)'
(.text+0x0): multiple definition of `MFRC522::MIFARE_OpenUidBackdoor(bool)'
(.text+0x0): multiple definition of `MFRC522::MIFARE_SetUid(unsigned char*, unsigned char, bool)'
(.text+0x0): multiple definition of `MFRC522::MIFARE_UnbrickUidSector(bool)'
*** [.pioenvs/uno/firmware.elf] Error 1
================================================================================== [ERROR] Took 2.02 seconds ==================================================================================
