Hi community,
I would like to know how to improve optimization of the flash of my esp32 (currently 90% used…)
Do I have to set something in the platformio.ini file ?
Thanks a lot
Hi community,
Thanks a lot
The default GCC optimization flag is already -Os (optimize for smallest size). Mabe link-time-optimization (LTO) can additionally do something (and not break the firmware like it sometimes does). See build_flags and -flto.
Otherwise, make sure that if you’re not using OTAA or a (big) filesystem to use an appropriate partition table that makes the best usage of the flash chip size you have on your particular board.
Thanks Max… but the flash size should be 4MB right ?
Why it is showing in this way?
How can I change the partition of the memory from platformio ?
Thansk
Thanks again
I just linked that piece of information above.
board_build.partitions = huge_app.csv
