Hello!
I’m currently working on an nRF52832 board based on adafruit-arduino framework. Recently I have decided to automate specific tasks after build process such as moving the binary from the “.pio/build” folder in the project to a folder called “release” in the project’s root folder. I wrote a custom script to accomplish this but facing errors. I have added the post build script here in the platformIO.ini
And the post_build_script_right.py looks like this:
The AddPostAction function runs in the beginning of the Build process rather than after the zip package is created.
I’m not sure if that was the intended use case for env.AddPostAction function. If so, I would like to implement it the correct way. Basically, wait for PlatformIO to generate zip package and run the post script
Any help regarding this implementation is appreciated!
