I’m writing an application with another developer for the ESP32.
I’m using the command line and the Espressif tools (idf.py, esptool.py, etc.
) and CMake. I’m writing the low level OS stuff.
My colleague is using PIO with VSC. He’s writing the app, which is really just an elaborate task that’s serviced by my OS layer.
With that in mind, I have my OS in one repository and he wants to be able to pull that OS project (written and developed within the CMake/ESP-IDF framework) into his repository so he can do his development with PlatformIO.
We’re running into a problem, because I need to have the app_main()
function, but PIO is punching back saying ‘no, no, no, I need app_main()
How should we handle this? What’s a sane workflow for this type of situation?
Ideally, if I make changes or improvements to the OS project, I want him to be able to do a little git-fu and be able to pull in the changes to the OS portion of his project, but as of right now, we can’t even figure out how to set up PIO to deal with a separate project having the keys to the car, so to speak.
Thank you!
