Hi , @ivankravets
How to manually push a new version to the Platformio registry manager?
I updated XPowersLib to version V0.1.6 some time ago, and I still found v0.1.5 when searching the platformio registry, but I cannot push the new version through pio.
Please tell me how I can update the version in registry by pio command.
I have tried to update using the pio pkg publish command before, but I got an error, whether it is win or ubuntu
lewis@lewis-virtual-machine:~/Documents$ ls
XPowersLib
lewis@lewis-virtual-machine:~/Documents$ pio pkg publish --type library ./XPowersLib/
Preparing a package...
File "/home/lewis/.local/lib/python3.10/site-packages/platformio/__main__.py", line 102, in main
File "/home/lewis/.local/lib/python3.10/site-packages/click/core.py", line 1130, in __call__
File "/home/lewis/.local/lib/python3.10/site-packages/click/core.py", line 1055, in main
rv = self.invoke(ctx)
File "/home/lewis/.local/lib/python3.10/site-packages/platformio/cli.py", line 70, in invoke
return super().invoke(ctx)
File "/home/lewis/.local/lib/python3.10/site-packages/click/core.py", line 1657, in invoke
File "/home/lewis/.local/lib/python3.10/site-packages/click/core.py", line 1404, in invoke
File "/home/lewis/.local/lib/python3.10/site-packages/click/core.py", line 760, in invoke
File "/home/lewis/.local/lib/python3.10/site-packages/platformio/package/commands/publish.py", line 104, in package_publish_cmd
archive_path = p.pack()
File "/home/lewis/.local/lib/python3.10/site-packages/platformio/package/pack.py", line 161, in pack
with FileUnpacker(src) as fu:
File "/home/lewis/.local/lib/python3.10/site-packages/platformio/package/unpack.py", line 138, in __enter__
self._archiver = self.new_archiver(self.path)
File "/home/lewis/.local/lib/python3.10/site-packages/platformio/package/unpack.py", line 153, in new_archiver
with open(path, "rb") as fp:
FileNotFoundError: [Errno 2] No such file or directory: './XPowersLib/'
`pip install -U platformio` command
Can you cd XPowersLib and then pio pkg publish --type library . ?
Tried various methods. Nothing works.
What was the error when you used the above commands?
Are you running the latest PIO core version? pio upgrade --dev if in doubt.
lewis@lewis-virtual-machine:~/Documents$ cd XPowersLib/
lewis@lewis-virtual-machine:~/Documents/XPowersLib$ pio pkg publish --type library .
Error: Unknown manifest file type in . directory
lewis@lewis-virtual-machine:~/Documents/XPowersLib$ pio upgrade --dev
Please wait while upgrading PlatformIO Core ...
PlatformIO has been successfully upgraded to 6.1.8a1
Release notes: https://docs.platformio.org/en/latest/history.html
So the XPowersLib folder has no library.json or where is it?
lewis@lewis-virtual-machine:~/Documents/XPowersLib$ ls
CMakeLists.txt examples keywords.txt library.properties Micropython README.md
datasheet Kconfig library.json LICENSE platformio.ini src
lewis@lewis-virtual-machine:~/Documents/XPowersLib$ cat library.json
"name": "XPowersLib",
"version": "0.1.7",
"description": "Arduino,CircuitPython,Micropython library for x-powers power management series",
"keywords": "AXP192 AXP202 AXP2101 x-powers",
"authors": [
"name": "LewisHe",
"url": "https://github.com/lewisxhe",
"maintainer": true
"repository": {
"type": "git",
"url": "https://github.com/lewisxhe/XPowersLib.git"
"homepage": "https://github.com/lewisxhe/XPowersLib",
"export": {
"include": [
"LICENSE",
"library.json",
"library.properties",
"README.md",
"keywords.txt",
"src/*",
"examples/*"
"frameworks": ["arduino", "espidf"],
"platforms": "esp32",
"headers": "XPowersLib.h"
What happens if you just pio pkg publish --type library in that directory?
Okay, there’s no need to pass in any parameters, just publish it. Thank you for your help
