Hello !
I am trying to make .bin files from my usual .cpp files and I have no idea how to do that.
I am trying to implement Firmware Update by uploading a .bin file.
I have never used PIO Commands. I’ve only used CTRL+ALT+B and CTRL+ALT+U.
[env:esp32-evb]
platform = https://github.com/platformio/platform-espressif32.git
board = esp32-evb
board_build.flash_mode = qio
upload_port = /dev/ttyUSB0
monitor_port = /dev/ttyUSB0
upload_speed = 115200
build_flags = -DCORE_DEBUG_LEVEL=5
#libraries
lib_deps = https://github.com/me-no-dev/ESPAsyncWebServer.git
https://github.com/me-no-dev/AsyncTCP.git
PlatformIO already generates .bin files as part of the compile process… if you browse to the .pioenvs / .pio/build / name-of-env folder of your project, you’ll find firmware.bin.
Alternately, it’s mentioned as one of the last few lines of the build process, and you should get a message about being able to Ctrl + Click on the path to navigate to it… which will at least find the file for you in the sidebar.
I found the firmware.bin inside /project_name/.pioenvs/esp32-evb
But I don’t get a message about it when I build.
This is all I get:
Processing esp32-evb (framework: arduino; platform: https://github.com/platformio/platform-espressif32.git; board: esp32-evb)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32-evb.html
PLATFORM: Espressif 32 > OLIMEX ESP32-EVB
HARDWARE: ESP32 240MHz 320KB RAM (4MB Flash)
DEBUG: CURRENT(esp-prog) EXTERNAL(esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
Collected 29 compatible libraries
|-- <ESP Async WebServer> 1.2.2 #b0c6144
| |-- <AsyncTCP> 1.1.0 #d1f28ff
| |-- <WiFi> 1.0
| |-- <FS> 1.0
|-- <WiFi> 1.0
|-- <SPIFFS> 1.0
| |-- <FS> 1.0
Retrieving maximum program size .pioenvs/esp32-evb/firmware.elf
Checking size .pioenvs/esp32-evb/firmware.elf
DATA: [= ] 11.9% (used 38968 bytes from 327680 bytes)
PROGRAM: [====== ] 62.1% (used 813682 bytes from 1310720 bytes)
============================================================================== [SUCCESS] Took 1.92 seconds ==============================================================================
You get WAAAAY more info than me.
Yeah… just ran it again… and didn’t get it. It’s because it was a from scratch build. If I clean the build files out it’ll take a while to rebuild everything, and will show it. Could probably add a extra_script to show that… but it’s easy enough to find the file if needed.
Yep. It makes the firmware.bin only if you’ve actually changed something to the code.
Great. Thanks !
