i am new to platformio and i struggle with linking libraries in my project. My first goal is, that i can compile the following minimal example.
#include <pbc.h>
void setup() {}
void loop() {}
That pbc.h can be found i added in the platformio.ini a line with build flags:
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
build_flags= -I ~/.local/include/pbc -L ~/.local/lib -Wl,-rpath ~/.local/lib -l pbc -lgmp
When i try to compile it, i got the following error message:
> Executing task in folder pbcTest: platformio run <
Processing nodemcuv2 (platform: espressif8266; board: nodemcuv2; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 2.5.1 > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 3.20701.0 (2.7.1)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20800.0 (2.8.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
Found 29 compatible libraries
*** [.pio/build/nodemcuv2/firmware.elf] TypeError `Tried to lookup File '/home/thomas/.platformio/platforms/espressif8266/builder/~/.local/lib' as a Dir.' trying to evaluate `${_concat(LIBDIRPREFIX, LIBPATH, LIBDIRSUFFIX, __env__, RDirs, TARGET, SOURCE)}'
============================= [FAILED] Took 1.15 seconds =============================
Reading the error message, i think the programm looks in the wrong directory for the needed libraries. It should look in ~/.local/include and ~/.local/lib but i think it looks in /home/thomas/.platformio/platforms/espressif8266/builder/~/.local/lib .
How can i achieve it, that the compiler looks in the right directory for the needed libraries?
Maybe as additional information: I am using Linux and when i compile a test file with gcc test.c -I ~/.local/include/pbc -L ~/.local/lib -Wl,-rpath ~/.local/lib -l pbc -lgmp
everything works fine.
