How to know if this is the first env?
Maybe I’m seeing the problem wrongly, but here is my little issue.
I have a pio script, executed for each environments I have. It generate files that are global to all envs (a auto version.h file with build number inside).
When I execute pio run, I can see the script being executed multiple time, for each environment) that make the generation of the file multiple times in my case.
One solution is to only create the file only if it does not exist (this requires me to manually remove this file)
The best solution is to know when pio run is executing the first environment, so that I know that I can generate the file. But I don’t see how I can get this information.
Maybe there is a better way that I do not see.
Thanks!
Not sure if this an X/Y problem, but okay.
Consider
[env]
extra_scripts = test.py
[env:uno]
board = uno
[env:nanoatmega328]
board = nanoatmega328
And
Import("env")
this_env = env.subst("$PIOENV")
print("This env name: " + this_env)
platform = env.PioPlatform()
print("The platform config: " + str(platform.config))
for e in platform.config.envs():
    print("Env name: " + str(e))
all_env_names = [str(e) for e in platform.config.envs()]
is_this_the_first_env_in_the_file = this_env == all_env_names[0]
print("Are we currently building in the first environment of the file? " + str(is_this_the_first_env_in_the_file))
Thus
Processing uno (platform: atmelavr; board: uno; framework: arduino)
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (5.0.0) > Arduino Uno
DEBUG: Current (avr-stub) External (avr-stub, simavr)
 - framework-arduino-avr @ 5.2.0
Found 5 compatible libraries
This env name: uno
The platform config: <ProjectConfig C:\Users\Max\temp\test_envs\platformio.ini>
Env name: uno
Env name: nanoatmega328
Are we currently building in the first environment of the file? True
Checking size .pio\build\uno\firmware.elf
RAM:   [          ]   0.4% (used 9 bytes from 2048 bytes)
Flash: [          ]   1.4% (used 444 bytes from 32256 bytes)
======================== [SUCCESS] Took 2.27 seconds ========================
Processing nanoatmega328 (platform: atmelavr; board: nanoatmega328; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/nanoatmega328.html
PLATFORM: Atmel AVR (5.0.0) > Arduino Nano ATmega328
HARDWARE: ATMEGA328P 16MHz, 2KB RAM, 30KB Flash
This env name: nanoatmega328
Env name: uno
Are we currently building in the first environment of the file? False
Checking size .pio\build\nanoatmega328\firmware.elf
Flash: [          ]   1.4% (used 444 bytes from 30720 bytes)
======================== [SUCCESS] Took 2.22 seconds ========================
Great! Thank you so much!
