simon
1
Hi all,
I’m facing weired issues and want to try increasing stack and heap.
I found .ld script in .platformio/packages/framework-arduinoststm32/variants/STM32F0xx/F030R8T
But changing does not increase stack.
I’m checking the size with:
/* get stack size */
volatile uint16_t i = ((uint16_t)((uint32_t)&_Min_Stack_Size));
i++;
i is always 1024.
Where can I increase the stack?
Best,
Simon
This symbol is constant, you cannot change it. Make a copy of Arduino_Core_STM32/ldscript.ld at main · stm32duino/Arduino_Core_STM32 · GitHub in the project folder’s root under a different name (e.g. custom_ldscript.ld
), change the values as you want, and set
; add this folder to the linker paths so that ld script can be found
build_flags = -L.
; redirect ldscript
board_build.ldscript = custom_ldscript.ld
(docs).
simon
3
Thank you Mr. @maxgerhardt ! Good to know.
