How to include a custom library
Hi, I tried to create my first private library and add it to the lib directory. My structure is effectively as follows:
lib
|-- myLibrary
---    |-- lib (files that are needed by the source files
---    |-- src
---        |-- libfile.h
---        |-- libfile.cpp
---        |-- FolderA
--- ---            |-- libfileA.h
    |-- library.properties
my library.properties has the following contents
name=myLibrary
version=1.0.0
author=michox
maintainer=michox
sentence=Define a repository of Peripheral sensors, actuators, and external devices
paragraph=
category=Device Control
url=https://github.com/myLibrary
architectures=*
however, when I try to include the file from my project src or include directory it will fail to build. I want to include libfileA.h and I tried several methods but at the moment I can’t even include libfile.h. I tried
#include "libfile.h"
#include "myLibrary/src/libfile.h"
#include <myLibrary/libfile.h"
but nothing worked. I am really clueless at this point and some help would be really appreciated!
I find the following structure works best for PlatformIO libraries:
lib
+---MyLib
        +----- MyLib.h
        +----- MyLib.cpp
I don’t bother with the src directory beneath lib/MyLib. Everything works fine for me that way.
Cheers,
Norm.
Hey Norm, Thanks for the tip. Unfortunately, it is a complex library with about 5 levels, I just simplified it here, a flat structure is not possible in my use case.
Only libraries of the documented structure are supported, sadly. For you it might even help to put all source files and sub-folders into src/.
I had the same issue.
My structure is as follows:
lib
|-- myLibrary
---    |-- src
---        |-- libfile.h
---        |-- libfile.c
By adding the library folder name to platformio.ini, this issure is fixed.
	myLibrary
lib_ldf_mode = deep+
In main.cpp,include the lib like this:
#include <libfile.h>
Hope this helps.
