I’m using VS Code to write code for STM32 using stm32cube framework. I want to use C++ instead of C but by default code is compiled in C.
env.Replace(
AR=“arm-none-eabi-ar”,
AS=“arm-none-eabi-as”,
CC=“arm-none-eabi-gcc”,
CXX=“arm-none-eabi-g++”,
GDB=“arm-none-eabi-gdb”,
OBJCOPY=“arm-none-eabi-objcopy”,
RANLIB=“arm-none-eabi-ranlib”,
SIZETOOL=“arm-none-eabi-size”,
ARFLAGS=["rc"],
SIZEPROGREGEXP=r"^(?:\.text|\.data|\.rodata|\.text.align|\.ARM.exidx)\s+(\d+).*",
SIZEDATAREGEXP=r"^(?:\.data|\.bss|\.noinit)\s+(\d+).*",
SIZECHECKCMD="$SIZETOOL -A -d $SOURCES",
SIZEPRINTCMD='$SIZETOOL -B -d $SOURCES',
PROGSUFFIX=".elf"
I changed CC=“arm-none-eabi-gcc” to CC=“arm-none-eabi-g++” in main.py builder file to check whether code gets compile without error and it works.
I don’t want to change the file just for one project. Is there a build flag that forces code to compile in CPP?
