my
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
upload_port = COM4
upload_protocol = esptool
upload_port = COM3
upload_speed = 115200
Hello.
You appear to have two upload_ports in your platformio.ini file, COM3 and COM4. You would need to determine which one is correct, and given that COM3 doesn’t work, it’s probably COM4.
Also, is this always the case when you plug this particular board in to your Windows PC? I mean, do you always get COM4? Or do you get other com ports, depending on the usage at the time?
You can try leaving the upload_port out of platformio.ini as the uploader can usually make a good guess at determining the correct port.
HTH
Cheers,
Norm.
