I want to use uxTaskGetSystemState()
function of ESP32S3 in arduino framework and I am using
#define CONFIG_FREERTOS_USE_TRACE_FACILITY
#define configUSE_TRACE_FACILITY 1
still error: undefined reference to ‘uxTaskGetSystemState’
I noticed that someone mentioned that it was possible to compile the ESP source code and start the trace facility in Menuconfig
, but after compiling the source code, a replaces the native "framework-arduinoespressif32"
dependency, But are the menuconfig config config compiled from source and PIO generated dependencies the same? Or which “*.a” files should I replace?
measuring-task-execution-time
This is where I use uxTaskGetSystemState()
void showUserAllTask(void *pvParam)
Stream *stream = (Stream *)pvParam;
TaskHandle_t *TaskList;
uint8_t TaskNum = uxTaskGetNumberOfTasks();
TaskList = (TaskHandle_t *)malloc(TaskNum * sizeof(TaskHandle_t));
if (TaskList == NULL)
stream->println("[E][Show Task]TaskList malloc failed.");
vTaskDelete(NULL);
else
TaskNum = uxTaskGetSystemState((TaskStatus_t *)TaskList, TaskNum, NULL);
stream->printf("**************Task List**************\n");
stream->println("Ser.\tTaskName\tHandle");
for (uint8_t i = 0; i < TaskNum; i++)
stream->printf("%d\t%s\t%p\n", i, pcTaskGetTaskName(TaskList[i]), TaskList[i]);
stream->printf("[I][Task]TaskNum:%d\n", TaskNum);
free(TaskList);
vTaskDelete(NULL);
