Created a bare bones project.
Main.c
#include <stdio.h>
#include "freertos/task.h"
#include <esp_system.h>
extern const uint8_t favicon_ico_start[] asm("_binary_web_favicon_ico_start");
extern const uint8_t favicon_ico_end[] asm("_binary_web_favicon_ico_end");
void app_main()
const uint32_t favicon_ico_size = (favicon_ico_end - favicon_ico_start);
printf("Size: %u", favicon_ico_size);
platformio.ini
framework = espidf
board_build.embed_txtfiles = web/favicon.ico
When I compile I get the following.
Compiling .pio\build\esp32dev\src\main.o
Linking .pio\build\esp32dev\firmware.elf
c:/users/jim/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\src\main.o:(.literal.app_main+0x0): undefined reference to `_binary_web_favicon_ico_end'
c:/users/jim/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\src\main.o:(.literal.app_main+0x4): undefined reference to `_binary_web_favicon_ico_start'
*** [.pio\build\esp32dev\firmware.elf] Error 1
The latest core is 5.2.x. 3.2.0 is impossible and core 2.3.2 should be too old to build anything. Can you post the exact versions as they appear in the build log, e.g.
and in the CLI with pio --version?
I think that just the wrong versions / combination of your used version and docs is at play here.
mikemoy:
Regardless, if you follow this Link
It says, you can use board_build.embed_txtfiles = your file.
As the note says though it must be used in addition to the CMakeLists.txt declaration when using ESP-IDF.
Thanks for the help!
PS C:\Users\Jim\Documents\PlatformIO\Projects\zzz> pio --version
PlatformIO Core, version 5.1.1
Ran a update:
PS C:\Users\Jim\Documents\PlatformIO\Projects\zzz> pio update
Updating platformio/contrib-piohome 3.3.4 @ ~3.3.4 [Up-to-date]
Updating platformio/tool-scons 4.40100.2 @ ~4.40100.2 [Up-to-date]
Platform Manager
Platform espressif32
Updating platformio/espressif32 3.2.0 [Up-to-date]
Updating platformio/toolchain-xtensa32 2.50200.97 @ ~2.50200.0 [Up-to-date]
Updating platformio/toolchain-esp32ulp 1.22851.191205 @ ~1.22851.0 [Up-to-date]
Updating platformio/framework-arduinoespressif32 3.10006.210326 @ ~3.10006.0 [Up-to-date]
Updating platformio/framework-espidf 3.40200.210118 @ ~3.40200.0 [Up-to-date]
Updating platformio/tool-esptoolpy 1.30000.201119 @ ~1.30000.0 [Up-to-date]
Updating platformio/tool-cmake 3.16.4 @ ~3.16.0 [Up-to-date]
Updating platformio/tool-ninja 1.9.0 @ ^1.7.0 [Up-to-date]
Updating platformio/tool-mconf 1.4060000.20190628 @ ~1.4060000.0 [Up-to-date]
Updating platformio/tool-idf 1.0.1 @ ~1.0.1 [Up-to-date]
Library Manager
Library Storage: C:\Users\Jim\.platformio\lib
Build Output
> Executing task: C:\Users\Jim\.platformio\penv\Scripts\platformio.exe run <
Processing esp32dev (platform: espressif32; board: esp32dev; framework: espidf)
-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (3.2.0) > Espressif ESP32 Dev Module
- framework-espidf 3.40200.210118 (4.2.0)
- tool-cmake 3.16.4
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-idf 1.0.1
- tool-mconf 1.4060000.20190628 (406.0.0)
- tool-ninja 1.9.0
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
- toolchain-xtensa32 2.80400.210114 (8.4.0)
Found 0 compatible libraries
==================================================================================================== [FAILED] Took 10.64 seconds ====================================================================================================The terminal process "C:\Users\Jim\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
Does that last information I gave help in any way why the “bare bones project” does not compile?
What’s the CMakeLists.txt in the root and in src/ of the project?
root CMakeLists.txt
cmake_minimum_required(VERSION 3.16.0)
include($ENV{IDF_PATH}/tools/cmake/project.cmake)
project(zzz)
src CMakeLists.txt
# This file was automatically generated for projects
# without default 'CMakeLists.txt' file.
FILE(GLOB_RECURSE app_sources ${CMAKE_SOURCE_DIR}/src/*.*)
idf_component_register(SRCS ${app_sources})
platformio.ini
framework = espidf
What happens if you add
target_add_binary_data(${COMPONENT_TARGET} "web/favicon.ico" BINARY)
to the end of the root’s CMakeLists.txt?
Adding to root cmakelist.txt
project(zzz)
Compile result
fatal: not a git repository (or any of the parent directories): .git
CMake Error at CMakeLists.txt:5 (target_add_binary_data):
target_add_binary_data Function invoked with incorrect arguments for
function named: target_add_binary_data
I have tried this before, this is why I asked if the docs are up to date.
I found the solution. Note, I made a new folder named website under the src folder.
Placed this in platformio.ini
src/website/favicon.ico
src/website/index.html.gz
src/website/config.html.gz
Then in CMakeLists.txt in src folder I added this.
target_add_binary_data(${COMPONENT_TARGET} "website/favicon.ico" TEXT)
target_add_binary_data(${COMPONENT_TARGET} "website/index.html.gz" TEXT)
target_add_binary_data(${COMPONENT_TARGET} "website/config.html.gz" TEXT)
and in main.c added this and now it compiles.
extern const uint8_t favicon_ico_start[] asm("_binary_favicon_ico_start");
extern const uint8_t favicon_ico_end[] asm("_binary_favicon_ico_end");
extern const uint8_t index_html_start[] asm("_binary_index_html_gz_start");
extern const uint8_t index_html_end[] asm("_binary_index_html_gz_end");
extern const uint8_t config_html_start[] asm("_binary_config_html_gz_start");
extern const uint8_t config_html_end[] asm("_binary_config_html_gz_end");
However, this is a big issue here that I discovered. Whenever I add a a new new file, and add the accompanying code for it (like above) it wont compile. I found that if you do a clean all first the recompile it will. This is a repeatable issue.
mmccdev
October 20, 2021, 8:33pm
31
I can confirm this solution (or workaround) works and what is marked as a solution / what should be done per Platformio documentation doesn’t.
Thank you mikemoy.
Ok, but how do you do this for unit testing?
There is no CMakeLists.txt file in the test directories.
Looking at the provided platformio examples, all only have a readme in the test directory.
u03
May 23, 2022, 9:09am
33
Thanks this solved my issue, it is not clearly described in the documentation.
