I want to copy a project to another project keeping the same board settings, or rename an existing project name.
If I right click on a project in the IDE and select duplicate or rename nothing happens.
Same issue. Dont know how to move on…
Just open project in system file manager and rename/copy to other location. Then go to IDE and click on “Menu: PlatformIO > Open project” and select new location. All settings will be saved. If you don’t need some projects in TreeView, right click on a project and “Remove project”. In this case, the source files will not be deleted. The only link from TreeView will be removed.
