I have a custom board with an STM32L152RE, and I’m trying to program it using the ST-Link that I detached from a Nucleo board. Using the Arduino IDE, I can program it without any issues, but I can’t do it with Platformio because I get an error: “Error: target voltage may be too low for reliable debugging.” I know this error is because the programmer is not receiving the voltage from the microcontroller on the “voltage target” pin. I’m not interested in using the debug feature for this board. Is there a way to disable the debug in the platformio.ini file so it doesn’t attempt to debug and thus avoids this error?
What is the exact output of a verbose upload? CLI → pio run -t upload -v
Hi Max, thanks for your early reply, here the output.
Processing nucleo_l152re (platform: ststm32; board: nucleo_l152re; framework: arduino)
-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/nucleo_l152re.html
PLATFORM: ST STM32 (17.4.0) > ST Nucleo L152RE
HARDWARE: STM32L152RET6 32MHz, 80KB RAM, 512KB Flash
- framework-arduinoststm32 @ 4.20701.0 (2.7.1)
- framework-cmsis @ 2.50900.0 (5.9.0)
- tool-dfuutil @ 1.11.0
- tool-dfuutil-arduino @ 1.11.0
- tool-openocd @ 3.1200.0 (12.0)
- tool-stm32duino @ 1.0.2
- toolchain-gccarmnoneeabi @ 1.120301.0 (12.3.1)
Found 12 compatible libraries
MethodWrapper(["checkprogsize"], [".pio\build\nucleo_l152re\firmware.elf"])
RAM: [ ] 1.3% (used 1104 bytes from 81920 bytes)
Flash: [ ] 1.6% (used 8484 bytes from 524288 bytes)
.pio\build\nucleo_l152re\firmware.elf :
section size addr
.isr_vector 316 134217728
.text 7828 134218044
.rodata 556 134225872
.ARM.extab 0 134226428
.ARM 8 134226428
.preinit_array 0 134226436
.init_array 16 134226436
.fini_array 8 134226452
.data 100 536870912
.bss 1004 536871012
.noinit 0 536872016
._user_heap_stack 1536 536872016
.ARM.attributes 41 0
.comment 57 0
.debug_line 1620 0
.debug_line_str 282 0
.debug_info 1885 0
.debug_abbrev 420 0
.debug_aranges 96 0
.debug_str 2002 0
.debug_frame 96 0
.debug_loclists 2424 0
.debug_rnglists 172 0
Total 20467
<lambda>(["upload"], [".pio\build\nucleo_l152re\firmware.elf"])
AVAILABLE: blackmagic, cmsis-dap, jlink, mbed, stlink
openocd -d2 -s C:\Users\FernandoVelasquez\.platformio\packages\tool-openocd/openocd/scripts -f board/st_nucleo_l1.cfg -c "program {.pio\build\nucleo_l152re\firmware.elf} verify reset; shutdown;"
Licensed under GNU GPL v2
For bug reports, read
debug_level: 2
Info : clock speed 300 kHz
Info : STLINK V2J33M25 (API v2) VID:PID 0483:374B
Info : Target voltage: 0.004728
Info : [stm32l1.cpu] Cortex-M3 r2p0 processor detected
Info : [stm32l1.cpu] target has 6 breakpoints, 4 watchpoints
Info : starting gdb server for stm32l1.cpu on 3333
Info : Unable to match requested speed 300 kHz, using 240 kHz
[stm32l1.cpu] halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x0800175c msp: 0x20014000
STM32L: Enabling HSI
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
** Programming Started **
Info : Device: STM32L1xx (Cat.5/Cat.6)
Info : STM32L flash has dual banks. Bank (0) size is 256kb, base address is 0x8000000
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
shutdown command invoked
It has uploaded the code perfectly fine. The verify has gone through. It’s just complaining about the target voltage but it doesn’t matter.
Also, the error message cannot be disabled in OpenOCD. When it has a ST-Link that’s not in Device Firmware Update (DFU) mode, it will measure the voltage, and will log and error.
The only way you can avoid this is if you don’t use OpenOCD + ST-link as your uploader combination, but instead use a different debug tool (CMSIS-DAP?) or a program that doesn’t give a frick about it. I guess the Arduino IDE was using stm32cubeprog? You can define a custom upload command as needed in upload_protocol — PlatformIO latest documentation
Thanks Max, if is programming ok, I’ll leave that way.
