I had some trouble understanding what to do exactly, so I figured I’d try to help by answering the question of how to define a board from within the project files and not from within the .pio General file locations.
find a reference board project .json file using a similar package framework .json file for a board found in the
C:\Users\{$USER}\.platformio\platforms\{$PLATFORM}\boards
files. -
once you have a project setup. create a folder called “boards” in the root project directory chosen.
copy the reference board .json file into the “boards” folder,
rename the file to whatever you want to call the board,
edit the .json to meet your needs.
And that’s it. Your custom board will be referenced when the project is built.
reference link : Custom Embedded Boards — PlatformIO v6.1 documentation
my example :
