I’m working on a new project and am trying to do native unit testing of shared code.
Environment details
MacOS 11.6.2
VSCode: 1.63.2
PlatformIO extension: 2.4.0
PlatformIO Core: 5.2.4
Getting the unit test project set up and building was straightforward enough, but trying to debug in VSCode is proving very difficult.
I’ve installed gdb from Homebrew, and changed my project environment to be ‘native’. However, whenever I try to start a debugging session I get an error like this:
Processing native (platform: native)
Found 1 compatible libraries
Building in debug mode
Reading symbols from /XXX/.pio/build/native/program...
Warning: 'set target-async', an alias for the command 'set mi-async', is deprecated.
Use 'set mi-async'.
PlatformIO: debug_tool = None
Temporary breakpoint 1 at 0x100004ec4: file test/test_native/main.cpp, line 6.
PlatformIO: Resume the execution to `debug_init_break = tbreak main`
PlatformIO: More configuration options -> https://bit.ly/pio-debug
Unable to find Mach task port for process-id XXXX: (os/kern) failure (0x5).
(please check gdb is codesigned - see taskgated(8))
I see similar errors if using pio debug -e native --interface gdb
I tried the obvious fix here (code signing gdb with a self-signed certificate), but that doesn’t actually resolve the issue. Trying a hack where I symlink gdb to lldb doesn’t work either as lldb uses different command line options.
Has anybody actually been able to get this kind of native debugging working in PlatformIO on a Mac?
