How to create custom launch tasks?
I am working on a cross-platform project that requires me to build, run and debug my codebase on various embedded boards as well as on desktop computers. This is a bit tricky, though, because PlatformIO keeps rebuilding the launch.json file in VSCode overwriting any custom launch configurations that may have been added.
Is there a way to properly and permanently add an additional LLDB desktop launch configuration to PlatformIO so that I can select whether I want to run any of my embedded builds or a desktop build?
Does this help at all? I have been meaning to give it a try to see what it actually does, but having quite got there yet…
https://docs.platformio.org/en/latest/ide/vscode.html#custom-tasks
Not from what I can tell. This is to create custom tasks and yes, it works. However, launch configurations are entirely separate from tasks from what I can tell, so that this does not help with my actual problem.
The launch.json is automatically generated by PIO and I do not know where it actually retrieves the information from so it is not possible to add or modify these launch configurations. :frowning:
No one has had the need to create custom launch tasks before?
launch.json is created from the template file located at https://github.com/platformio/platformio-core/tree/develop/platformio/ide/tpls/vscode/.vscode. You can add static new content to that. On your computer it should be under <home directory/.platformio/penv/Lib/site-packages/platformio/ide/tpls/vscode/.vscode
Thanks so much for tip! Couldn’t find the file at first but then located it in <home directory/.platformio/penv/Lib/Python2.7/site-packages/platformio/ide/tpls/vscode/.vscode instead.
Made the change and it works!!! :slight_smile:
