vit
1
I added
${env.build_flags}
-lgcov
--coverage
-fprofile-abs-path
Now need to create html/lcov reports. Technically, that looks like “run script after tests”. But, surprisingly, this is not possible.
Currently ended with custon target:
import os
import shutil
Import("env")
out_dir = 'coverage'
env_name = env['PIOENV']
root = env.subst('$PROJECT_DIR')
def create_out_dir(target, source, env):
if os.path.exists(out_dir):
shutil.rmtree(out_dir)
os.makedirs(out_dir)
env.AddCustomTarget(
name="coverage_report",
dependencies=None,
actions=[
create_out_dir,
f"platformio test -e {env_name}",
f"lcov -d .pio/build/{env_name}/ -c -o {out_dir}/lcov.info",
f"lcov --extract {out_dir}/lcov.info '{root}/src/*' '{root}/include/*' -o {out_dir}/filtered_lcov.info",
f"genhtml -o {out_dir}/ --demangle-cpp {out_dir}/filtered_lcov.info"
title="Coverage Report",
description="Run tests and generate coverage report"
But would like to have somethiing less “hacky”, IMHO custom target is overkill for such obvious demand. Could you advice anything?
I also need this. I am generating the test- coverage with gcovr:
gcovr --sort uncovered-number --sort-reverse --html-nested -e .pio* -o ./test/coverage/main.html
This command should run after all tests have run.
Currently I switch to the terminal, repeat the latest command.
But automating it would be nice.
I will take a look at AddCustomTarget to see if this would work for me. All unit testing is already setup in a dedicated environment.
Since the documentation doesn’t contain anything - at least I haven’t found anything
- on the subject, it looks like a missing feature to me.
I have not tested but there is a “private” target named __test. Could you test this snippet?
def after_test(source, target, env):
print("after_test")
# do some actions
env.AddPostAction("__test", after_test)
See Pre & Post Actions — PlatformIO latest documentation
Also, you can try env.AddPostAction("$PROGPATH", callback...)
arduhe
5
I’ve added
extra_scripts = post:extra_script.py
to the [env] section of my platformio.ini and added extra_script.py to the main folder of my project containing this
Import("env")
print("Current CLI targets", COMMAND_LINE_TARGETS)
print("Current Build targets", BUILD_TARGETS)
print("######### after_test ###########")
# do some actions
Neither running pio test -vvv nor running pio run --target __test -vvv shows the expected output
but they show
Current CLI targets ['upload', '__test']
Current Build targets ['upload', '__test']
respectively
Current CLI targets ['__test']
Current Build targets ['__test']
vit
6
Seems this doesn’t work.
I’ve seen this approach in issue tracker. IMHO looks more cryptic than custom target.
- IMHO, feature “do something after test” is missed (may be even “after test success”).
- Probably, coverage could have better support, but this is subjest to discuss, and anyway (1) is needed.
In ideal world, I would like to have this things:
- Generating coverage report
- select format (lconv / HTML)
- filter dirs - usually only src/include of project needed (no deps / no sys headers)
That’s only preliminary opinion, “after test hook” will be enough to make things useable without pain.
