Anyone know how to create a .lst (Assembly) file from a .elf file during the build process in PlatformIO?
Regards,
Fred
Regards,
Fred
You invoke objdump of the toolchain with the -d
option followed by the path to the produced elf file. That’s one post action script away.
What is the proper structure of the path to the .elf file?
Thanks,
Fred
See the last few lines of the example code
# Custom HEX from ELF
env.AddPostAction(
"$BUILD_DIR/${PROGNAME}.elf",
env.VerboseAction(" ".join([
"$OBJCOPY", "-O", "ihex", "-R", ".eeprom",
"$BUILD_DIR/${PROGNAME}.elf", "$BUILD_DIR/${PROGNAME}.hex"
]), "Building $BUILD_DIR/${PROGNAME}.hex")
Just need to replace $OBJCOPY with e.g. arm-none-eabi-objdump
and the arguments with just -d
Max:
Thanks, for your answer, but how do I execute this file automatically from my built?
Is this a separate file in my build somewhere?
Sorry for my lack of knowledge about the inner workings of PIO.
Thanks,
Fred
