How to change partition scheme for ESP32?
Trying to use SPIFFS for my application. I can get some basic code to work in arduino IDE by changing to the “minimal spiffs” partition scheme however when I copy the same code over to VS and use
board_build.partitions = min_spiffs.csv
in the platformio.ini file SPIFFS fails to mount as though I used the wrong scheme. Can’t figure out what exactly I’m supposed to do. I thought I did what it says in the docs. Using ESP32-S3-devkitC from expressif. Thanks in advance for finding whatever obvious thing I’m missing.
What’s your full platformio.ini and the Arduino-ESP32 version installed in your Arduino IDE? (Tools → Boards → Board Manager → esp32)
Was version 2.0.3 in arduino IDE. Tried updating. Same results in 2.0.5.
The entire platformio.ini file is as follows:
[env:esp32-s3-devkitc-1]
board = esp32-s3-devkitc-1
	khoih-prog/ESP32_PWM@^1.3.3
	bblanchon/ArduinoJson@^6.19.4
Can you take a screenshot of the Arduino IDE → Tools menu for reference?
Here’s all the settings.
Seems flash_mode was not correct by default for esp32-s3-devkitc-1. Setting it to qio fixed it.
These settings now work as expected.
board_build.flash_mode = qio
board_build.f_flash = 80000000L
board_build.partitions = default_8MB.csv
Is this now fixed in the IDE?
I wonder why platformio needs duplicating these settings. It should pick up the configuring from menuconfig, shouldn’t it?
