How to capture and store data simtaneously from two ADC [PA0,PA1] pin STM32?
Goal
In STM32F103, with External trigger(Timer3 TRGO) Capture data from for two ADC pin PA0 and PA1.
Plan here
  1. ADC2 configured to PA0 pin then Storing data via ADC Interrupt
  2. ADC1 configured to PA1 pin capture in DMA Channel 1 via DMA interrupt data 3. is stored
    Both ADC1 and ADC2 is trigger by Timer 3 TRGO input
Code used here
// Interrupt service routine for the timer
void setup_timer3_ADC_PA0_PA1()
    // ADC2 used to meaursing the GA pin (Voltage/Current).
      1. Setting up Timer 3 to Output TRGO
      2. Setting up ADC2 to Trigger on Timer 3 TRGO
      3. From the ADC2 Conversion Complete Interrupt I will store the ADC data
      4. Start the ADC2
    // Setup ADC2 to Trigger on Timer 3 TRGO
    __HAL_RCC_ADC2_CLK_ENABLE();
    hadc2.Instance = ADC2;
    hadc2.Init.ScanConvMode = ADC_SCAN_DISABLE;
    hadc2.Init.ContinuousConvMode = DISABLE;
    hadc2.Init.DiscontinuousConvMode = DISABLE;
    hadc2.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T3_TRGO; // Triggered by Timer 3 TRGO
    hadc2.Init.DataAlign = ADC_DATAALIGN_RIGHT;
    hadc2.Init.NbrOfConversion = 1;
    HAL_ADC_Init(&hadc2);
    ADC_ChannelConfTypeDef adc2ChannelConfig = {0};
    adc2ChannelConfig.Channel = ADC_CHANNEL_0;   // Selected pin PA0
    adc2ChannelConfig.Rank = ADC_REGULAR_RANK_1; // For ADC2, this should be Rank 1.
    adc2ChannelConfig.SamplingTime = ADC_SAMPLETIME_28CYCLES_5;
    HAL_ADC_ConfigChannel(&hadc2, &adc2ChannelConfig);
    // Setting up Timer 3 to Output TRGO
    __HAL_RCC_TIM3_CLK_ENABLE();
    timer3_set_interval(100, 10);
    // Enable interrupt for ADC1_2
    HAL_NVIC_SetPriority(ADC1_2_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(ADC1_2_IRQn);
    // ADC1 used to measure the AFC pin
    // Setup ADC1 to Trigger on Timer 3 TRGO
    __HAL_RCC_ADC1_CLK_ENABLE();
    hadc1.Instance = ADC1;
    hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
    hadc1.Init.ContinuousConvMode = DISABLE;
    hadc1.Init.DiscontinuousConvMode = DISABLE;
    hadc1.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T3_TRGO; // Triggered by Timer 3 TRGO
    hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
    hadc1.Init.NbrOfConversion = 1;
    HAL_ADC_Init(&hadc1);
    ADC_ChannelConfTypeDef adc1ChannelConfig = {0};
    adc1ChannelConfig.Channel = ADC_CHANNEL_1;   // Selected pin PA1
    adc1ChannelConfig.Rank = ADC_REGULAR_RANK_1; // ADC1 configured here
    adc1ChannelConfig.SamplingTime = ADC_SAMPLETIME_28CYCLES_5;
    HAL_ADC_ConfigChannel(&hadc1, &adc1ChannelConfig);
    // DMA controller clock enable
    __HAL_RCC_DMA1_CLK_ENABLE();
    hdma_adc1.Instance = DMA1_Channel1;
    hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_adc1.Init.MemInc = DMA_MINC_ENABLE;
    hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
    hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
    hdma_adc1.Init.Mode = DMA_CIRCULAR;
    hdma_adc1.Init.Priority = DMA_PRIORITY_MEDIUM;
    HAL_DMA_Init(&hdma_adc1);
    __HAL_LINKDMA(&hadc1, DMA_Handle, hdma_adc1);
    // The link between hadc1 and hdma_adc1 was completed via:
    uint8_t ADC_BUFLEN = 10;
    HAL_ADC_Start_DMA(&hadc1, &buffer_adc_AFC, ADC_BUFLEN); // Link DMA to ADC1
    // DMA interrupt init
    // DMA1_Channel1_IRQn interrupt configuration
    HAL_NVIC_SetPriority(DMA1_Channel1_IRQn, 1, 0); // Second priority than ADC interrupt
    HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);
// interrupt handler for ADC 1 & 2
extern "C" void ADC1_2_IRQHandler(void)
    HAL_ADC_IRQHandler(&hadc2);
extern "C" void DMA1_Channel1_IRQHandler(void)
    HAL_DMA_IRQHandler(&hdma_adc1);
        // Check if transfer is complete
    if (__HAL_DMA_GET_FLAG(&hdma_adc1, DMA_FLAG_TC1))
        // Transfer complete: Process or analyze data in adc1_data_buffer
        store_AFC_data(&buffer_adc_AFC);
        // Clear the DMA transfer complete flag
        __HAL_DMA_CLEAR_FLAG(&hdma_adc1, DMA_FLAG_TC1);
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef *hadc)
    if (hadc->Instance == ADC1)
        int16_t adc_pa0 = HAL_ADC_GetValue(hadc);
        if (adc_capture_data_enable)
            if (measure_volt_flag || measure_current_flag)
                store_VI_data(adc_pa0); // Store Voltage data
void store_VI_data(int16_t _sdata)
    // Circle or Ring Buffer to store data Volt, Current Measure data
    // NOTE: Here only memory pointing variable is used.
    _adc_sample_time_gap += (micros() - _timer3_record);
    _adc_sample_time_gap /= 2;
    _timer3_record = micros();
    if (measure_volt_flag)
        if (volt_sample_count < _sample_size)
            volt_sample_count++;
        else
            volt_sample_count = 0;
        volt_raw_data[volt_sample_count] = _sdata;
    else if (measure_current_flag)
        if (current_sample_count < _sample_size)
            current_sample_count++;
        else
            current_sample_count = 0;
        current_raw_data[current_sample_count] = _sdata;
void store_AFC_data(uint32_t *_sdata2)
    if (AFC_sample_count < _sample_size)
        AFC_sample_count++;
    else
        AFC_sample_count = 0;
    AFC_raw_data[AFC_sample_count] = _sdata2[0];
Problem
After flashing this code STM32 is getting hang. I trying many combined still unable get a proper ADC
Related my previous posts
cc: maxgerhardt
Can yo u upload the project as a whole? In the debugger, where is it getting stuck? Does it hardfault, or hang up in an interupt, or what’s happening there.
It is hanging once DMA interrupt is enabled.
Facing difficult in find issue in DMA implementation with interrupt.
