Hi I am working with esp32 with platformio…
From a .cpp file under the lib folder how can I include the following header file ?
#include <esp32-hal-time.h>
Thanks a lot
Thanks a lot
That should already be correct – is there an error after doing an IntelliSense rebuild (Ctrl+Shift+P → Intelli)?
Adding the following include
#include <esp32-hal-time.c>
and then calling the following function
getLocalTime(&time_test);
causes the crash of the firmware…
But compiling i don’t have issues…
Can you tell me why Max ?
Thanks
Sorry I measread the header file name (timer instead of time).
The functions should be available when just using
#include <time.h>
does that work better?
If not, post the full code.
I can especially recomment just using this piece of code
